I'm looking for a solution for my 308 vehicle |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (2008-2013) | |
| 08.05.2020 18:48 | # 1 |
One year ago, I had a BRC brand tube in my blue one. It has been giving antipollution faulty error for two months and stopping while the vehicle is going directly stops if I start again. It was doing it all the time, I brought the car to brc and pejo service, the injectors filters changed everything, I had the car serviced, this problem still has not changed. They deleted their mistakes in the Pejo service, and those errors are already coming up again. And this error still repeats. I tried everything, it doesn't fix, the psa module started to happen after that to fix the gasoline gauge which was installed later. And most importantly, it decreases nearly 1 liter of oil at 3 thousand km, and runs out of water. What am I supposed to do, what might be the reason? |
| 08.05.2020 18:48 | # 2 |
I've done the vehicle before |
| 08.05.2020 18:48 | # 3 |
I can't say anything to burn it, but if the water is running out there is somewhere escapes or if the foxfire has done as the friend says, oil and water may be mixing.
| 08.05.2020 18:48 | # 4 |
When I looked at the car, it will not look. Could it have something to do with the error? The car gives lpg errors when it connects to the computer. |
| 08.05.2020 18:48 | # 5 |
Lately, my problem has increased a lot, the vehicle stops continuously on the road, the water decay continues, even after the vehicle turns off the fan house, it runs for 6-7 minutes with a loud voice. What problem can it be? Is there anyone who can help?
| 08.05.2020 18:48 | # 6 |
My friend, If the vehicle decreases water and there is not enough water left in the system, icing occurs in the condenser due to the feature of LPG. As a result of the icing, the engine stops because the gas cannot pass through the condenser. When your vehicle stops, open the hood and check the temperature of the LPG head by hand. If it's cold, my thesis is correct. It occurs primarily when Gas or gasoline cannot be burned completely. this is caused by the ignition (spark plug or coil) problem. However, if the spark plug or coil malfunction, the PP2000 tester will definitely show. |
| 08.05.2020 18:48 | # 7 |
I do not know the leaks, but if the malfunctions do not go away, look at the brain and say it to the electronics store.
| 08.05.2020 18:48 | # 8 |
If your vehicle has colored antifreeze, leakage will be evident in the waterways. If there is no colored antifreeze, change the water and add colored antifreeze. Make sure that the air is taken when the water changes. Check for leaks. Use your vehicle for a while, check whether oil reduction and misfire stop. crime is also lpg if it gives no error while using gasoline. but if there is a problem in the vehicle's own system, it will show in petrol. And keep in mind that the engine with shortage of gasoline will react bigger at lpg. |
| 08.05.2020 18:48 | # 9 |
muro_60 |
Water is circulating in half of the lpg regulator.
| 08.05.2020 18:48 | # 10 |
Hello my friend, I do not know if the problem is still going on, but the same incident happened in my hundayi era brand vehicle. After having the lpg installed, the car stopped one day while it was moving on the road and continued in the same way. I immediately went to the master and explained the situation, after 6 hours of uninterrupted inspection, he said that the fuse had blown, then he disconnected the electric cables. The result was molten intertwined cables. It changed and the problem was interrupted. By the way, the brand of the tube I had was brc. Hopefully this style is something easy to solve.
| 08.05.2020 18:48 | # 11 |
If the problem is solved, it would be great if you write
