I'm looking for a 307 good master
08.05.2020 15:05 # 1
friendkalp
hello friends 307 my clutch set timing set will change a solid master and how much will I spend as a price?
I am in Istanbul hunters friendkalp 2011-02-04 15:49:27
08.05.2020 15:05 # 2
peugeotefe
Let's help you write how many engines diesel gasoline
08.05.2020 15:05 # 3
The original triger set price can be up to 200 mercury ... a solid master can receive up to 100 rubles. Because the triger apricot change is very important. The escape of the sente overrides the whole machine ...
efe helps you from ikitelli ...
the cecol 2011-02-04 15:56:37
08.05.2020 15:05 # 4
[QUOTE = peugeotefe] Let's help you write how many engines diesel gasoline [/ QUOTE]
efe will help. you
sensitive issue because as cecoli says sentence setting is very important
the albaydemirc 2011-02-04 15:59:42
08.05.2020 15:05 # 5
friendkalp
307 2004 1,4 diesel
08.05.2020 15:05 # 6
peugeotefe
Clutch Kit 240 tl
Timing Set 130 TL
I'm in circulation 55 TL
Transmission oil 25 tl
2 axle felts 15 tl
Labor 300 TL
08.05.2020 15:05 # 7
friendkalp
Are you wearing and are the parts original? friendkalp 2011-02-04 16:26:52
08.05.2020 15:05 # 8
peugeotefe
Yes, we are assembling
08.05.2020 15:05 # 9
ACHTUNG
teacher I will ask you something
How much is 4-wheel brake pad for 307?
thanks
08.05.2020 15:05 # 10
peugeotefe
LUK brand of printing pad
Timing set SKF
Same parts used in the service
08.05.2020 15:05 # 11
friendkalp
TSK Thank you, if you write the address and tel, I would be happy because I entered on the phone, I can not see some things
08.05.2020 15:05 # 12
peugeotefe
[QUOTE = ACHTUNG] [QUOTE = peugeotefe] how many engines of diesel, let us help you write petrol [/ QUOTE]
thanks
4 wheel brake pads 100 TL
08.05.2020 15:05 # 13
peugeotefe
[QUOTE = friendkalp] TSK Thank you if you write the address and tel, I would appreciate it because I entered from the phone I cannot see some things [/ QUOTE]
İkitelli Org. Singing. Plenty. Atatürk san. Sit. 10. street no 280 auto efe İkitelli / istanbul
0531 363 67 66
0212 486 33 66
08.05.2020 15:05 # 14
Faruk
[QUOTE = friendkalp] hello friends 307 my clutch set timing set will be a solid master and how much will i pay for the price?
I'm in Istanbul hunters [/ QUOTE]
If there is a tremor in the take-off and the 2000 times there, look at the flywheel and let them all out while having it done.
I need to change the flywheel and the press brake, but I want it to go as far as it goes and I am waiting for the text Kahkaha
08.05.2020 15:05 # 15
metin
I want to ask a question when the ready topic is opened.
What is it with 4 disc workmanship?
How much is the front team?
How much is crank pulley + labor? good work.
08.05.2020 15:05 # 16
peugeotefe
When you say the front tool, if you open it, which parts are not defective or defective, I will give the price to 2 front disks, but the back discs of the 307s are 2 types of removable pory type, without the type, it is necessary to disassemble and look inside it. peugeotef to 2011-02-04 18:43:04
