I'm looking for 16 "5 spoke 307 wheels
08.05.2020 15:18 # 1
forewer_fb
friends looking for 16 "5 spoke wheels for 306, I am waiting for your help ...
08.05.2020 15:18 # 2
If you are asking the original of the 16 "307 5-spoke rim, it is not suitable for the car itself ... because the offset of that rim is 31 crazy.
In order to use it, you need to use the spacer side flash. You need to find a quality spacer for this, otherwise it may not balance. Chances will keep good money. You will also need to use long bobbins. I never recommend you ...
the same rim has a 15 "zero zero 500. With 20 offset ... 195 55 will be the number 10 with 15 tires.
Or if you say I will use 16 "wheels, the rim in the picture has a width of 6.5" with 18 offset and 750 TL. You can use it with 195 50 16 tires
the cecol 2011-04-19 15:13:00
08.05.2020 15:18 # 3
forewer_fb
I say at least 16 because it does not show 15 rims but I did not know that there was such a problem.
08.05.2020 15:18 # 4
Haksen016
This wheel named lincancabur, shown by cecolin, is a number 10 rim friend.
08.05.2020 15:18 # 5
forewer_fb
Actually, the only question I can think of is if it is good on the car.
08.05.2020 15:18 # 6
forewer_fb
I found 16 inches to 680 rubles zero
08.05.2020 15:18 # 7
Haksen016
best wishes. Are you getting.
08.05.2020 15:18 # 8
forewer_fb
The only problem I have in mind is how it will stop, in fact, there is a situation like this, as it can be understood from the title, I was looking for 307 wheels but now it is a little out of date and this wheel will be different. Have you ever seen this wheel in a vehicle?
08.05.2020 15:18 # 9
[QUOTE = forewer_fb]
I saw it very beautiful. call me before my beautiful brother bought a rim tire. If you don't worry about the press then don't say it ...
look at the link ... this tool is the tool of our alper atakan.
I think it looks very nice. I thought I would wear it too. but the car is hard, I gave up. Ten teams are breaking faster. It is also more expensive in tires.
the cecol 2011-04-20 21:02:23
08.05.2020 15:18 # 10
Don't think your beautiful brother will be on every rim you find. the offset phenomenon and the width of the rim are very important. Not all the rims that you see are the same ...
you can also use it with 195 50 16 tires. 185 65 14 tun 16 "one is the equilibrium ... but many people wear 45 16. This time it is very hard ...
08.05.2020 15:18 # 11
forewer_fb
It looks good, okay, I'm fine, I will call you, cem brother, 195 50 16 users will be at least a bit of hardness.
08.05.2020 15:18 # 12
look, I changed my message ... atakan again put the rim and tire on sale :))))))
08.05.2020 15:18 # 13
35kz829
I think follow the photos of 306 vehicles from google, look at the rims attached then make your decision so don't regret it
