I'm in the process of getting a Peugeot 508 1.6 ThP |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 508 | |
| 08.05.2020 19:41 | # 1 |
While I was in the process of upgrading my car, the Peugeot 508 option came to me. 1.6 THP allure model 2011 model 95000 is also a vehicle. I liked it very much, when the seller gave it at an affordable price. I think I'm going to take over the vehicle on Monday. For this reason, I consider myself a Peugeot owner. However, there are serious questions in my head .. I would be glad if you share your thoughts. 1. A motor master I know (in Bostanci auto industry) confirmed that there was no problem with the vehicle's bonnet. There is no serious accident. Vehicle Triptronic F1 with automatic gear. But it also stressed that the automatic gearboxes of the Peugeot vehicles were very problematic and that I might regret it. This comment is correct. How often the transmission is a problem in these vehicles. I Korkmalimiy? 2. The engine runs a little noisy, although it is not heard from inside the vehicle. Is this normal? 3. We made a trial pack. The monster on the straight track of the vehicle. gear shifts are not felt. But it is slow to accelerate when it is at low speed. Especially in the automatic transition from 1 to 2, the vehicle is piling up. Is this because the engine has a big engine against the body of the vehicle or is it unusual? Is it possible to have to put the F1 gear of the car and come out with a 1st gear when it is hard to get an example while leaving a hill? Or does this indicate the possibility of a transmission failure? In the meantime, the owner of the vehicle advised me to use this tool in manual mode in the beginning of the slope in order not to damage the transmission. ???????????????? Vehicle 156 hp ... 4. The pressure lining of the vehicle has changed at 70,000 km .. during which periods is it normal to change? 5. The desired figure for this vehicle is 43.500 ... Should I consider it a cheap and a malady? I am excitedly waiting and waiting for your suggestion. I took your time .. thank you |
