I'm confused by the choice of 307 tires |
| 08.05.2020 15:11 | # 1 |
| 08.05.2020 15:11 | # 2 |
Sasma from the usual brands, does not miss cheaply in the tire. I am using GoodYear EfficientGrip and I am satisfied. I do not think there is much difference between them. We are normal users, so we do not care about factors that have minor effects such as 1%. Besides, if a tire has an increase in one subject, there is absolutely but absolutely nothing in another. Like two scales of the scale. It doesn't always happen anymore, the pluses should bring cons. There is only one point, which is high quality production. So I think you would be pleased if you bought one of the brands like Michelin, GoodYear, Bridgestone. |
| 08.05.2020 15:11 | # 3 |
I say that the tire that does not like good year does not understand from work, many quality brands use it as the original tire, but it is not surprising from the known brands.
| 08.05.2020 15:11 | # 4 |
prelli and good year are not good brands. they wear out in a short time ...
| 08.05.2020 15:11 | # 5 |
iibrahimm |
KEEP CHEAP REMOTE EAST BUILDING FINE DON'T KEEP THE BEST POSTS AT THE FIRST ATTENTION THAT MAKES 130 U GECTINMI TITREME IF YOU MAKE THE BALAN SET
| 08.05.2020 15:11 | # 6 |
I think the subject of the tire is important. Tires that hold the car. It is not worth for 30-40 lira. It is important to hold the vehicle on the ground.
| 08.05.2020 15:11 | # 7 |
metin |
I recommend the nokian h model. Starts from 130 TL. finland goods. it also has the title of being the quietest tire in the world. Meanwhile, nokian tires are also the owner of the Nokia mobile phone company.
