I'm calling out to friends who are 206 1.4 hdi ..? |
| 08.05.2020 17:54 | # 1 |
| 08.05.2020 17:54 | # 2 |
I use it between 2000 and 2500 cycles, as I know, the turbo 1800s come into play. Didn't you say this problem?
| 08.05.2020 17:54 | # 3 |
yes, the turbo opens at max torque and it starts at 1750-2000 and 3000 rpm, I think I heard this second gear situation before, it seems normal to me. use by paying attention to the rpm - flow rate.
| 08.05.2020 17:54 | # 4 |
Exactly, even when I give a lot of gas in the rainy weather, if I turn a light barrier, after 2000 cycles, the car escapes under my car and falls on skating. sometimes I think the car isn't 1.4 ![]()
| 08.05.2020 17:54 | # 5 |
[QUOTE = samet2461] just like that, even when I give a lot of gas in the rainy weather, if I turn a light barrier, after 2000 cycles, the car escapes under my car and falls on the skid. sometimes I think the car isn't 1.4 ![]() [/ QUOTE] exactly there is also a skid traction on the steep slope that is harmful to the mind ![]() |
| 08.05.2020 17:54 | # 6 |
My vehicle is also engaged in the turbo at 2500 rpm.
| 08.05.2020 17:54 | # 7 |
There is a problem with me as if there is a problem, mine is being hung in the period of 1.900 2.000 and counts where it is until after 3,000-4000 continue. I observed up to 5,000 hangings at 1.2, and 3.4 at gears. Note: I could not remember the name, there was air measurement stapler, it made a malfunction, engine light was on me, it was like the car was not going at 3000 rpm. (as a performance) then I renewed that thing. returned to normal it was as I wrote above. |
| 08.05.2020 17:54 | # 8 |
my friends found a turbo that missed a grease. Also, the friend says the air flow meter, let me tell you something about it.
