I'm Burning From A / C Heat |
| 08.05.2020 14:16 | # 1 |
I have the 2002 model 307, I have a problem I have been complaining for a long time, I have a digital air conditioner in my car, so much hot air comes out when the air conditioner is turned off, I can't even hold the steering wheel of the car, I sweat inside the car, when I put it into service, they say "it's normal" , but in my last visit, I got the master seated for 10 minutes, and of course he couldn't bear the heat, he had to believe me, he got the air conditioner, he did something, he said "the thermostat is broken 200 TL" :) meanwhile, his authorized servant ... I looked at the old subjects. I have been in trouble, what could be my problem, did the master make up, now I am in Antalya, I would be glad if you suggest a place where I can show the car other than the authorized service ...
| 08.05.2020 14:16 | # 2 |
Hi; And if we get to know you .. Our members who have completed their new membership and entered the forum, please introduce yourself by opening a new topic under the heading "Let's Know Our Members". Filling in all the information will help us to get to know you better. 1.- Your name and surname: 2.- Your age: 3.- Your vehicle (Brand, model): 4.- Your hobbies: 5.- Your profession: 6.- Where did you hear the site: 7.- Your Blood Group: 8.- Your horoscope: 9.- The team you support: 10.- Which county or province are you in: 11.- Your MSN address: Thank you for your attention. |
| 08.05.2020 14:16 | # 3 |
Long Beach |
Have it serviced, if you do not get a result, take the thermostat back and get your money back
| 08.05.2020 14:16 | # 4 |
okan77 |
What will be the problem in my 307s? What is the digital air conditioner working principle .... When it is fully cooled, does it turn off (at 14) or what should be done to keep the air temperature inside the same?
| 08.05.2020 14:16 | # 5 |
Long Beach |
If your air conditioner is automatic, you will say it or not. Also, if the difference between indoor and outdoor air temperature exceeds 9ºC, you and your car I remind you that it is very dangerous, especially facial paralysis. It doesn't joke, I know people who have a stroke. |
| 08.05.2020 14:16 | # 6 |
can32 |
Normally when you operate the air conditioner, you can get light cold at 17-18 degrees, so you can get normal cold air for that degree ???? If you can not get it, it is likely to be from the thermostat that measures the temperature of the inside of the cabin if it blows hot without falling to 14. If it is from this piece and you do not want to buy a new one, you can disassemble it and continue using it. but in this case, the auto function of the air conditioner will be disabled. |
| 08.05.2020 14:16 | # 7 |
okan77 |
I did not fully understand ... I can get cold air in the 19/20s ... I do not understand, or I do not know ... After a certain working interval, the air conditioner turns off ... after a few minutes, it works again spontaneously. How can it work? keep the coolness constant ... What is the use of the Auto part?
| 08.05.2020 14:16 | # 8 |
can32 |
If you can get cold air in the 19/20s, it is probably not from the thermostat. but of course he wasn't talking to the master. Now they have an in-car thermostat, they measure the internal temperature of this vehicle and evaluate it accordingly. Sometimes this thermostat breaks down and sends too hot or too cold values to the brain of the air conditioner. I know it from me. As such, no matter what degree you set it blows what makes sense to itself. so this is the statement made to me. As for the auto part, when this feature is on, the air conditioner works until it catches the temperature you set there and stops when it catches. works again when the temperature changes. If you turn off and start this feature, if only A / C remains on, that is, you can get cold air at any level you want. The auto feature is deactivated by pressing the blowing intensity buttons, and starts blowing continuously at the set intensity |
| 08.05.2020 14:16 | # 9 |
Friends, my air conditioner never stops :) If I say at 14 degrees, if I say at 20 degrees it always works :) I think the thermostat is really broken
| 08.05.2020 14:16 | # 10 |
If there is hot air coming in while driving off while on the screen, there is only one reason, you should press the silicon button, which is the circular arrow on the upper right side of the air conditioning panel.
| 08.05.2020 14:16 | # 11 |
In addition, there is no thermostat in 307. Change the part from the service. If you call me for detailed explanation 05558472211 I will help
| 08.05.2020 14:16 | # 12 |
BuRCaK |
Digital air conditioner working principle is as I know: The air conditioner is turned on, the auto button is pressed, the desired degrees are selected.It will blow very strongly at first because the interior of the car is hot. When the temperature of the inside reaches the desired temperature, the blowing decreases and fixes the heat by itself. Digital air conditioner is great comfort this fact. |
| 08.05.2020 14:16 | # 13 |
[QUOTE] saying no thermostat when my fan is overheated at 957, this event is all about thermostat
