I'm 306 and the problem
08.05.2020 16:55 # 1
Mfirat
Greetings .. I write the problems, show me a little bit :(
* When the car is going to 70, the gear speed is about 2 thousand rpm, but when it stops, it drops to 1100. When I press the clutch, the sound is cut off. My clutch is very hard.
* The bosda throttle is basically like 4 thousand. 50 I see the 2nd Gear 95 very comfortably .. But sometime it started to burn a little too long.
08.05.2020 16:55 # 2
kirmizi306
LPG limi gasoline in your vehicle?
& nbsp; - The late fall of the tachometer can be solved by the throttle cleaning. Or there is a problem with the sensors. It also does the gas adjustment. If it is the same in me, it is like the throttle but only LPG It can also be corrected with gas adjustment.
& nbsp; - When it comes to clutch problem, it seems like the pressure pad is finished.
08.05.2020 16:55 # 3
Mfirat
I did the throttle cleaning on saturday, all the air intake pipes cleaned the filter ga throttle with gasoline also doing the lpg too.
08.05.2020 16:55 # 4
Mfirat
steering box also failed :) peugeot = problem benn i understand it either
08.05.2020 16:55 # 5
volkan22
I think you ate the engine according to the 1st and 2nd levers :) You breathe with your mouth my pass & nbsp; on the empty gear & nbsp; 2000 rpm throttle & nbsp; on the way wind blows from the butterfly, the air is still, the butterfly is sensorude ole perceptions ... mi duser :) & nbsp; & nbsp;
If you say the electric supurge in another failure is interrupted when the clutch is pressed, the pressure is definitely in the lining pad & nbsp; If your vehicle needs a good maintenance, I think that all of these failures will not happen all of a sudden. The room associated with the leftover could possibly be in the throttle, but if the engine is seriously malfunctioning, it will continue to make it clicks ...
volkan22 2012-07-30 23:22:52
08.05.2020 16:55 # 6
Mfirat
eyw .. :) milling ball & nbsp; what they said .. he said there is no rush he said normal rpm values, i am looking at my tool but they do not need to rush the top, they are normal we are biniosis ..
