I'll take xenon recommendation
08.05.2020 21:01 # 1
disocerydeli
have a good forum
Vehicle 307 1.6hdi 2006 model lens
I will order xenon from Hepsiburada but I do not fit or need advice (h1 / 7/11) right version
Products I've looked at
For Kısakar
For the tall
08.05.2020 21:01 # 2
your headlights will be h1 short and long h7 short. You can also look at the bulb type here. As a note, those with a long back sometimes do not fit in the headlight, so the back cover may not close. I suggest you look at the short types.
http://public.servicebox.peugeot.com/apddb/
1. Dipped headlights (H1-55 W or xenon lamp). CAUTION: ELECTRIC SHOCK HAZARD Replacing a Xénon-type lamp must be done by a PEUGEOT Authorized Service. 2. Main beam (H7-55 W). Koruyucu Remove the protective cap for the faulty bulb. Ayır Disconnect the connector. Una Press the tip of each retaining hook. Replace the bulb. Make sure that the guiding notches are well positioned and the retaining hooks are well locked during assembly.
08.05.2020 21:01 # 3
maximusti
+ high beam does not have xenon,
When the xenon lights up the headlight, the headlight turns on for about 4 to 5 seconds. If you connect it to the long, you need to hold the handle for 4 to 5 seconds to make the selector.
For tall people, it should be either a led bulb, a white halogen bulb or a complete xenon headlight.
08.05.2020 21:01 # 4
maximusti
I made direct comments without looking at the products, these products are not xenon, but led bulb. :)
I have been using the C6 brand for more than 1 year in length, I am very happy with its lighting and selector power, but it did not fit my 206+, I am traveling with the back cover open.
08.05.2020 21:01 # 5
disocerydeli
I do not understand my teacher, I saw that it illuminates strongly as a picture, so I want to buy these products that I have given are not xenon or better or worse.
08.05.2020 21:01 # 6
OguzhanKucuk61
Xenon is another Led, another teacher. The product that you need to buy, which is good in terms of efficiency, is led. As the Soner brother said, those with a long fan part prevent the cover from closing. I bought it on aliexpressten. The fan part is short. Mine is 10,000 lumens. At least it says so in the box LOL That's why 4200 lumens came to me. I do not have clear information about the brand, but prefer a quality known product.
08.05.2020 21:01 # 7
maximusti
[QUOTE = disocerydeli] I don't really understand my teacher, I saw the image is strong, so I want to buy these products I give are not xenon or better or worse [/ QUOTE]
led is better,
You can see the photos and video I took for the same brand on the subject I wrote in my message above.
