I'll get your 207 I want your help |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 207 | |
| 08.05.2020 21:15 | # 1 |
I intend to buy a car for a long time and it will be my first car (I'm not experienced about vehicles) I want to buy 207 vehicles until 30-31 until scarce, but does it upset me, will it cost me (this situation varies depending on the vehicle, but) I have some chronic problems in vehicles and in my environment, I usually call it pejo electronic malfunction too veritor. If there is a problem, it will shake my budget Do you think I can buy a car that will not upset me at the prices I specified? What are your suggestions, thanks from the following |
| 08.05.2020 21:15 | # 2 |
In addition ; I want a diesel vehicle, -My vehicles I find should be over 200.000 km. - There are 4-8 tramers that have changed the hood. If there is something like krdsm, for example, if there is something like this, do not get infected or if the car goes to look at the master, check the following, I would appreciate it if you have any suggestions.
| 08.05.2020 21:15 | # 3 |
I recently tried to buy the best car in the price range and the highest model I can buy due to the limited budget. Peugeot 206 2004 model quiksilver model. But things did not go as I expected. I have an extra cost of TL 5 thousand in mechanical engine parts. (Though my event is a little bit due to my own fault and friendly stake.) I plan to buy 207 in the near future, but I don't think there will be much to come from the car we will find around 30-31. Let me explain by sampling. Peugeot 206 pricing between 15 thousand TL and 30 thousand TL Peugeot 207 pricing between 25 thousand TL and 60 thousand TL In this case, let's say we have 30 thousand TL. Instead of buying 207 for 30 thousand TL, it prefers to buy 206 for 25 thousand TL. In any problem, I set aside 5 thousand tly. Of course, this is the experience I had from the friend pile I ate :) The stew account of cheap meat. If you can find a clean vehicle for around 30-31 thousand, it will definitely be taken at 207. I will also make a warning if you are going to buy a car soon. Do not rely on the Exper report and ask what the expander looks at when doing experiments on the vehicle. Experts have different packages. You deal with the seller and get the expertise in the highest package. If something different happens, the seller will pay for it. I had an expertise while I was buying the vehicle. Then I had a few problems and went to where I had an expertise. You didn't tell me these things. When I asked him if he did not write in the Exper report, the answer I got was annoyed me :) If you have never bought a second hand car, read the articles "Things to consider when buying a second hand car".
| 08.05.2020 21:15 | # 4 |
[QUOTE = ydlnz] In addition; I want a diesel vehicle, -My vehicles I find should be over 200.000 km. - There are 4-8 tramers that have changed the hood. If there is something like krdsm, for example, if there is something like this, do not get infected or if the car goes to look at the master, check the following, I would appreciate it if you have any suggestions. [/ QUOTE] Today, 4 to 8 thousand rubles of tramer seems normal to me. changing part is also quite normal. I think something about the user is something about Km. The man does not look at his car, it is 50 thousand km but the vehicle is miserable. You can use 200 thousand km clean, it is in a very good condition than the vehicle in 50 thousand km. You may not have trouble with km without exaggeration. Surely the appraisers whose names have been heard also get appraisals. As I said in my previous comment to escape from the expert's money. If you already choose the highest package and get an expertise, they make an extremely detailed report. From the front assembly to the rear layout, from engine oil leaks to the chassis. In addition, while looking at each vehicle, go directly to the expertise. First, drive around a bit. Don't rush. If you need 30 minutes and 45 minutes, take 1 hour. Walk the streets slowly and listen to their voices. Then get on the bus and look at the sounds of the vehicle shaking between 70-80-90 speeds. then look at the sounds of the vehicle shaking between 100-110-120 speeds. These are the things that come to my mind for now.
| 08.05.2020 21:15 | # 5 |
[QUOTE = umydn] I recently tried to buy the best car in the price range and the highest model I can buy due to the limited budget. Peugeot 206 2004 model quiksilver model. But things did not go as I expected. I have an extra cost of TL 5 thousand in mechanical engine parts. (Though my event is a little bit due to my own fault and friendly stake.) I plan to buy 207 in the near future, but I don't think there will be much to come from the car we will find around 30-31. Let me explain by sampling. Peugeot 206 pricing between 15 thousand TL and 30 thousand TL Peugeot 207 pricing between 25 thousand TL and 60 thousand TL In this case, let's say we have 30 thousand TL. Instead of buying 207 for 30 thousand TL, it prefers to buy 206 for 25 thousand TL. In any problem, I set aside 5 thousand tly. Of course, this is the experience I had from the friend pile I ate :) The stew account of cheap meat. If you can find a clean vehicle for around 30-31 thousand, it will definitely be taken at 207. I will also make a warning if you are going to buy a car soon. Do not rely on the Exper report and ask what the expander looks at when doing experiments on the vehicle. Experts have different packages. You deal with the seller and get the expertise in the highest package. If something different happens, the seller will pay for it. I had an expertise while I was buying the vehicle. Then I had a few problems and went to where I had an expertise. You didn't tell me these things. When I asked him if he did not write in the Exper report, the answer I got was annoyed me :) If you have never bought a second hand car, read the articles "Things to consider when buying a second hand car". [/ QUOTE] Thank you very much for the answer, I do not have any vehicle experience, I only look at the visual and my budget. Obviously, I have an alternative fiat punto grande. 206 seems so small I had a friend, I don't think so much
| 08.05.2020 21:15 | # 6 |
Thanks, the idea that you should stay away from the accident from the front is what you say in your people, the front door is different, for example, is it okay or should it stay away? |
| 08.05.2020 21:15 | # 7 |
[QUOTE = ydnmz] [QUOTE = umydn] I recently tried to buy the best car in the price range and the highest model I can buy due to the limited budget. Peugeot 206 2004 model quiksilver model. But things did not go as I expected. I have an extra cost of TL 5 thousand in mechanical engine parts. (Though my event is a little bit due to my own fault and friendly stake.) I plan to buy 207 in the near future, but I don't think there will be much to come from the car we will find around 30-31. Let me explain by sampling. Peugeot 206 pricing between 15 thousand TL and 30 thousand TL Peugeot 207 pricing between 25 thousand TL and 60 thousand TL In this case, let's say we have 30 thousand TL. Instead of buying 207 for 30 thousand TL, it prefers to buy 206 for 25 thousand TL. In any problem, I set aside 5 thousand tly. Of course, this is the experience I had from the friend pile I ate :) The stew account of cheap meat. If you can find a clean vehicle for around 30-31 thousand, it will definitely be taken at 207. I will also make a warning if you are going to buy a car soon. Do not rely on the Exper report and ask what the expander looks at when doing experiments on the vehicle. Experts have different packages. You deal with the seller and get the expertise in the highest package. If something different happens, the seller will pay for it. I had an expertise while I was buying the vehicle. Then I had a few problems and went to where I had an expertise. You didn't tell me these things. When I asked him if he did not write in the Exper report, the answer I got was annoyed me :) If you have never bought a second hand car, read the articles "Things to consider when buying a second hand car". [/ QUOTE] Thank you very much for the answer, I do not have any vehicle experience, I only look at the visual and my budget. Obviously, I have an alternative fiat punto grande. 206 seems so small I had a friend, I don't think so much [/ QUOTE] If you are looking for a wide range of Ford Focus. You can find very clean according to your budget. For some reason I do not look very warm at Fiat. Opel Corsa, Golf 4 chassis, Audi a3. Seriously you can buy beautiful Golf 4 or Audi A3 for 30-31 thousand TL. If it comes to your mind. It doesn't matter if the hood is different. The man had an accident from the left or right by the fender. There has been a skew in the hood. The other party is guilty. He changed it for free. The important thing is whether there are chassis, poles, changing process or paint in the luggage pool. By the way, these are my views. Unfortunately, there are people in Turkey's ridiculous prejudices. They say that a painted car is not bought, but the car with sunburn also breaks the price because it needs paint. What matters to me Chassis, poles, trunk, engine, mechanical, undercarriage, electronic components. If these are ok, I will get that vehicle. After all, we buy cars at the age of 10-20. The necessity of the accident dye will be changing. The important thing is that he does not have a serious accident.
| 08.05.2020 21:15 | # 8 |
Thank you again for the answers, my mind has changed even in 3-4 questions. It is not very important to have a wide vehicle, but it can be ford, but the body you mentioned 2006 MODEL FORD FOCUS FROM THE FIRST OWNER No: 679910299
Could it be https://www.sahibinden.com/ilan/vasita-otomobil-ford-2006-model-ford-focus-ilk-owner-679910299/detay etc. |
| 08.05.2020 21:15 | # 9 |
[QUOTE = ydnmz] thank you again for the answers, my mind changed even in 3-4 questions. It is not very important to have a wide vehicle, but it can be ford, but the body you mentioned 2006 MODEL FORD FOCUS FROM THE FIRST OWNER No: 679910299 Could it be https://www.sahibinden.com/ilan/vasita-otomobil-ford-2006-model-ford-focus-ilk-owner-679910299/detay etc. [/ QUOTE] The damage record of this vehicle is too much. It has a bottom case. you can find them very clean. I leave one example below. https://www.sahibinden.com/ilan/vasita-otomobil-ford-2001-model-ford-focus-1.6-comfort-bakimli-masrafsiz-696903048/detay
| 08.05.2020 21:15 | # 10 |
[QUOTE = umydn] I recently tried to buy the best car in the price range and the highest model I can buy due to the limited budget. Peugeot 206 2004 model quiksilver model. But things did not go as I expected. I have an extra cost of TL 5 thousand in mechanical engine parts. (Though my event is a little bit due to my own fault and friendly stake.) I plan to buy 207 in the near future, but I don't think there will be much to come from the car we will find around 30-31. Let me explain by sampling. Peugeot 206 pricing between 15 thousand TL and 30 thousand TL Peugeot 207 pricing between 25 thousand TL and 60 thousand TL In this case, let's say we have 30 thousand TL. Instead of buying 207 for 30 thousand TL, it prefers to buy 206 for 25 thousand TL. In any problem, I set aside 5 thousand tly. Of course, this is the experience I had from the friend pile I ate :) The stew account of cheap meat. If you can find a clean vehicle for around 30-31 thousand, it will definitely be taken at 207. I will also make a warning if you are going to buy a car soon. Do not rely on the Exper report and ask what the expander looks at when doing experiments on the vehicle. Experts have different packages. You deal with the seller and get the expertise in the highest package. If something different happens, the seller will pay for it. I had an expertise while I was buying the vehicle. Then I had a few problems and went to where I had an expertise. You didn't tell me these things. When I asked him if he did not write in the Exper report, the answer I got was annoyed me :) If you have never bought a second hand car, read the articles "Things to consider when buying a second hand car". [/ QUOTE] I am not someone who changes cars, I use it for at least 5 years. It didn't make any sense for me to pay the expert's money when selling. Somehow it was not in good faith to choose the most expensive package for the owner to pay. I did not pay expert money in any vehicle I sold. Our folks also do not accept if I made a strange expertise and give it to him, he also tries to go to his head and get the expert in the most expensive place and load the cost to the seller. Anyway, if we come to suggestion business. If you are going to buy a Peugeot, get well maintained. It is also high priced. You will get 306 but a clean 306. The problematic of the model you want is only from this money. There are a lot of people who can't afford it but still keep it in order.
| 08.05.2020 21:15 | # 11 |
If you are thinking about buying a second-hand car, I will write them in a corner of your mind. Be careful not to be accidental from the front (your front team does not keep order, your vehicle gets sound from all over) 1. The science examination has been recently, 2. Tires new 3. There is no oil leakage in the engine 4. No abnormality in engine sound 5. Authorized authorized serfis priority regular invoices are available 6. Wheel balls front tool and steering box 6. Places where you will spend the vehicle you want to buy. oil care tiriger, V-belt set discs and pads. Spark plugs in gasoline vehicle will change priority, the places where you can open the vehicle you will buy, starter motor, charge dynamo (alternator), radiator hoses and water, axles glass elevator ceiling sagging, air condition problem, routine failures that will follow. it will be
| 08.05.2020 21:15 | # 12 |
[QUOTE = ismailka A] 2. If you are thinking about buying a car, I will write it in a corner of your mind. First of all, let's have a good close repairman friend. Be careful not to be accidental from the front (your front team does not keep order, your vehicle gets sound from all over) 1. The science examination has been recently, 2. Tires new 3. There is no oil leakage in the engine 4. No abnormality in engine sound 5. Authorized authorized serfis priority regular invoices are available 6. Wheel balls front tool and steering box 6. Places where you will spend the vehicle you want to buy. oil care tiriger, V-belt set discs and pads. Spark plugs in gasoline vehicle will change priority, the places where you can open the vehicle you will buy, starter motor, charge dynamo (alternator), radiator hoses and water, axles glass elevator ceiling sagging, air condition problem, routine failures that will follow. it will be [/ QUOTE] Some things can be considered normal for vehicles aged 15-20. It is necessary to buy a vehicle at the age of zero or 5 to have at least half of the post.
| 08.05.2020 21:15 | # 13 |
Hello friends, I bought a peugeot 207 2008 model diesel vehicle 2 years ago. no changed paint damage record. The vehicle is now 170 thousand. Thank God there was no problem, except for the small evil eye. Nothing happens if you take care of it properly. If you look at the bond, do not look at the mountain. I added an extra stabilizer to the car. I had a double tape.
