I'll buy 308 rims and tires.
08.05.2020 19:29 # 1
Asli
My car was not long since 2009 308 automatic 3 weeks, and we stayed on the road due to overheat tractor, etc. The vehicle is not looking for more than 2 weeks, the radiator has not changed in repair.
08.05.2020 19:29 # 2
dream
First of all, have you not got hot? Of course, Bursa is one of the leading provinces in the automotive industry. (also my hometown)
I guess, since the search is made, the industry is also being built.
08.05.2020 19:29 # 3
Asli
The temperature has risen, of course, it suddenly rose, the stop lamp burned, we added water and continued on the road, then the fiasco. I do not recommend it to anyone
08.05.2020 19:29 # 4
samet206
First of all, let's get past. It is inevitable to be like this. I would like to share a few things that I know about it. First of all, the vehicle should not be stopped during the heat, and the water should not be supplemented. Secondly, we should not proceed without determining the source of the problem. It depends on how the vehicle is made and how you use it from now on.
08.05.2020 19:29 # 5
Barut
Routine or general packaging of the vehicle should be made before setting off on a long journey. I understand from what you say that you did not even look at the water of the car before you left the road, and the car has overheated due to the lack of water or you have put water on it and continued on the road. Sorry, but it's completely user error. I could not figure out what kind of logic it is to come to the peugeot forum and to disparage peugeot. Get well soon.
08.05.2020 19:29 # 6
Asli
Before going on the long road, we checked the oil and water, did not even have water, we even put water on the way back to the road, the water level, i.e. the temperature increased, the gentleman was probably not leaking or leaking or the fan was not activated at the time. After all, all of them are servant builders.
08.05.2020 19:29 # 7
switchman
The comments of friends are very correct, it seems to me like a user error because if your vehicle is overheated, it is not right to stop immediately, you should park the vehicle and wait for it to run at idle, then wait for the engine to cool down and add water and I'm sure that the engine will warm up and let the car get air if you put water and continue immediately If the radiator is running hot with cold water when the engine is hot, there is a risk of cracking the block and radiator. Even if you say how I will ride these, I would like you to know that water should be put into action while the engine is hot, so if I go through it, do not inflate my tires :)
