I just entered my age ...
08.05.2020 17:01 # 1
ahmetismet
Guys, I have been using 307 for about 1.5 years, so the tool is an electronic tool.
As you know, the front wipers of the vehicle are under the hood and like me, I tried to lift the wipers manually and I couldn't. There was a problem while washing the car. Then I looked at the service while replacing the wipers, the master removed the wipers "Big & nbsp; immediately jumped on how you did it.
You start and stop the vehicle and hit the wiper arm once in the direction of the steering wheel, the wipers are lifted. Wipers come down on the 2nd hit. "Clap"
08.05.2020 17:01 # 2
Alicilik
I know this feature is available in all pejo. You can learn everything by trying the Pejo mystery box. My arm slammed with the contact open, the wipers remained upright, then I was surprised, then headed out but we learned it here & nbsp; "Big
08.05.2020 17:01 # 3
tellotello
I have read in the user manual & nbsp; "Big
08.05.2020 17:01 # 4
Kadir
Do you have 206+ also tried this feature? When we say wiping the wiper arm in the direction of the steering wheel, do we draw ourselves right?
08.05.2020 17:01 # 5
Kadir
Our wipers can already be removed manually :)
08.05.2020 17:01 # 6
ekinoks44
I had this incident while wiping the car's window. I said the wipers were suddenly moving noluyoz: D
08.05.2020 17:01 # 7
ozaannn
How did I not understand? You hit the steering wheel, do you draw yourself?
08.05.2020 17:01 # 8
Kadir
I do not fully understand where we press the wiper arm.
08.05.2020 17:01 # 9
Alicilik
Hodja, stop the vehicle, remove the key from the ignition and lift the wiper arm up (1 stage open) and the wipers will come to the upright position. I haven't tried it, but it must have been until you removed the key (without opening the door) until BSi cut the electricity. For example, the windows are like that. If you turn off the ignition and pull the key, you can open and close the windshields until you open the door.
08.05.2020 17:01 # 10
ahmetismet
Stop while friends are running, do not remove the ignition. Tap the wiper arm short and fast as it burns long, it doesn't have to be too hard, then lower it in the same way. I don't know the 206's, my car is 307.
08.05.2020 17:01 # 11
metin
Since wipers are usually under putunka, they have put such a feature out of necessity. & Nbsp;
It is very useful when it is necessary to remove the wipers when it is snowing in winter.
08.05.2020 17:01 # 12
HLTYLMZ
For 407 & nbsp;
after stopping the vehicle it does not matter whether the key is in the contact or 30-40 sec. When it presses down the wiper arm once, it opens the wipers exactly 90 degrees, it brings it to the normal viewing position at the 2nd press. div>
08.05.2020 17:01 # 13
Kadir
Thanks. Apparently it depends on the model ...
08.05.2020 17:01 # 14
riva70
have excellent
08.05.2020 17:01 # 15
_semihk_
I knew, but I never thought it would be used in wiper development :)
08.05.2020 17:01 # 16
badcombatant
When I just bought the car, I was struggling a lot, but I couldn't change the wipers. I figured it out by chance.
"Thumbs
08.05.2020 17:01 # 17
tigerland
Happy Birthday :)
