I hit the gas, the vehicle accelerates later
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
08.05.2020 20:53 # 1
yucels
Hello friends.
With my 115 hp allure vehicle, which I have been using for the last year, the 2013 model pejo partner tepee, when I accelerate on the road when I need acceleration or overtaking, the speed is normal and I hear that the engine noise increases, but the acceleration is late. The first thing that came to my mind was that the pad was peeling off, but it was okay to grip the pad, but the engine screams as if it were on top of an ice acceleration comes after 1-2 seconds from behind and sometimes it does not.
In a cruise control , I fixed it to 100 km speed, going at 100 km speed, auto gas while wrapping up the ramp , when acceleration comes late, it comes out without fixing itself.
It is waiting for your help in solving these problems. I thank the friends who are interested.
08.05.2020 20:53 # 2
cyalman
If the speed of the vehicle is high, the stabilizer may be disengaged because the car does not accelerate because the speed comes out of the stabilizer. I think the problem will be solved when you find a solution to the problem of non-acceleration.
08.05.2020 20:53 # 3
tigrap
I have the same problem, I will follow the solution suggestions.
08.05.2020 20:53 # 4
Selcuk55
There were gas position sensors in the old partners, but I don't know if there are new ones.
08.05.2020 20:53 # 5
Beyinci_Ugur
Hi;
If the vehicle has a "DPF - particle" filter, it may be clogged.
If you pay attention to these details and write them, we can help you more
1- Is there an increase in fuel?
2- Does heavy exhaust smoke occur during gear shifting?
3- How many kilometers ago did the press-pad change take place, and are there any frequent skiders who use aggressive vehicles and stop and stop?
4- Are you buying the fuel regularly from a safe place or less mixed stations?
08.05.2020 20:53 # 6
KILIC
You can check the air filter first.
08.05.2020 20:53 # 7
yucels
Hello Brother. thank you for your interest.
1- no increase in fuel
2- no exhaust fumes
3- The press pad was 30000, I'm not an aggressive driver.
4- I regularly buy fuel from Aytemiz because it is the closest gas station to me.
