I Have Problems About 307 Help
08.05.2020 16:56 # 1
Mustafa Can
Hello, we bought the 2006 Pejo 307 for the first time, so I get on the pejo brand for the first time, so if I have a few questions, I ask you questions. What makes the solution crazy?
2-Parking sensor is working sometimes depending on the head.
08.05.2020 16:56 # 2
Mustafa Can
[QUOTE = Mustafa Can] Hello, we bought the 2006 Pejo 307 for the first time, so I get on the pejo brand for the first time, so if I have a few questions, my questions fade too fast on the slopes and do not pull off. I don't go as far and it makes me crazy. What can be the solution for this? ]
08.05.2020 16:56 # 3
tellotello
Is your vehicle automatic? Which model (1.4, 1.6)? How many horsepower (70, 90, 110)? If you mention these, I think you can give more comfortable answers to your first question. & nbsp;
My vehicle is diesel 2005 1.4 and these vehicles are 70 horsepower. Unfortunately, I wouldn't say that the uphill performances are very good. If I have not been able to enter quickly, it can drown very quickly, but it also depends on the slope you are trying to climb. A slightly steep slope that I am talking about. Other friends will be able to help more. & Nbsp;
08.05.2020 16:56 # 4
tellotello
I saw it now & nbsp; "Smile"
& nbsp;" 2006 307 1.6 auto xt premium "mus & nbsp;
08.05.2020 16:56 # 5
istanbullu_3886
2-Parking sensor is working sometimes depending on the head, sometimes it does not work. Why could this be the problem? ] If the vehicle does not get up again, especially when it stops on a slope, then there may be several reasons. When it comes to the parking sensor, the reverse gear sensor may be defective.
08.05.2020 16:56 # 6
Mustafa Can
My car does not have 1.6 110 hp atmospheric lpg yet it is 90,000 km but the gas does not come out until the end of it. I did not even get the speed of the garage when I was leaving the last slope.
08.05.2020 16:56 # 7
istanbullu_3886
diesel diesel gasoline of the vehicle ??????????
08.05.2020 16:56 # 8
metin
[QUOTE = istanbullu_3886] the diesel gasoline of the vehicle ?????????? [/ QUOTE]
There is no auto in the 307s diesel so the vehicle is gasoline.
08.05.2020 16:56 # 9
metin
The reason for the vehicle's accumulation may be due to the transmission. because I had the same vehicle, the engine is fine, even if the slope of the vehicle does not come off, it skids instead of fainting. ;
When it comes to parking sensor, sometimes it works, sometimes it doesn't work. It detects the back plug or if it detects when driving on a straight road. There is one called multifunction switch. The problem may be with him. & Nbsp;
08.05.2020 16:56 # 10
eray307
Put it in sports mode and try it, then it goes.
08.05.2020 16:56 # 11
berk2309
If it stacks or stays, solenoids are problematic for the vehicle or torque converter & nbsp;
08.05.2020 16:56 # 12
Mustafa Can
Friends, my vehicle is powered by a gasoline 110 hp automatic 5 times, when it stops on a steep slope, it does not officially stop at all.
08.05.2020 16:56 # 13
mustafah
[QUOTE = Mustafa Can] My friends car with gasoline 110 hp automatic 5 times, when I stopped on a steep hill, it does not officially get up, it does not make any movement as if it would stop, only the engine is running but does not go [/ QUOTE]
< div> I had the same malfunction. Show it to a motor master if the engine is good, there is a high probability that the gearbox has a torque converter, it may have failed. This part transfers the power of the engine to the transmission up to approximately 3000 rpm in a controlled manner. When it malfunctions, the vehicle gets up on the straight road but never transfers on slopes. & Nbsp; "Smile". If this malfunction occurs, the vehicle should accelerate less than usual even on straight roads (especially on departures). My recommendation is to show it to a master who understands fully automatic gear.
mustafah 2012-07-31 09:34:45
08.05.2020 16:56 # 14
mustafah
[QUOTE = Mustafa Can] My friends car with gasoline 110 hp automatic 5 times, when I stopped on a steep slope, it does not officially get up, it does not move as if it would stop, only the engine is running but does not go [/ QUOTE]
< div> Bi, even though you load on the gas, no speed increases, & nbsp; "Smile"
08.05.2020 16:56 # 15
Mustafa Can
[QUOTE = mustafah] [QUOTE = Mustafa Can] My friends car 110 hp automatic 5 times when I stopped on a steep slope, it does not officially get up, as if it would stop, does not make any movement, only the engine is running but does not go [/ QUOTE]
I had the same malfunction. Show it to a motor master, if the engine says good, there is a very high probability that the gearbox has a torque converter, it may have failed. This part transfers the power of the engine to the transmission up to approximately 3000 rpm in a controlled manner. When it malfunctions, the vehicle gets up on the straight road but never transfers on slopes. & Nbsp; "Smile". If this malfunction occurs, the vehicle should accelerate less than usual even on straight roads (especially on departures). My recommendation is to show it to a master who understands better than fully automatic gear. It is impossible for the vehicle's engine to be exhausted because it is 90,000 km, I guess you had this problem, too, when you changed the "Torque Convector", the problem disappeared? Thank you in advance :)
08.05.2020 16:56 # 16
mustafah
[QUOTE = Mustafa Can] [QUOTE = mustafah] [QUOTE = Mustafa Can] My friends vehicle 110 hp automatic 5 times when I stopped on a steep slope, it does not officially get up, does not make any movement as if it will stop, only the engine is running but does not go [/ QUOTE] I had the same malfunction. Show it to a motor master, if the engine says good, there is a high probability that the gearbox has a torque converter, it may have failed. This part transfers the power of the engine to the transmission up to approximately 3000 rpm in a controlled manner. When it malfunctions, the vehicle gets up on a straight road, but it never transfers on slopes. If this malfunction occurs, the vehicle should accelerate less than usual even on straight roads (especially on departures). My advice is to show it to a master who understands fully automatic gear. [/ QUOTE] Exactly, it is good to take off on a straight road, but it does not move on a bulky steep ramp, the engine will only rotate the gas, but it will not move at all.It is impossible for the car's engine to be exhausted because I think you have experienced this problem at 90.000 km. Did you have a problem when you changed the "Convector"? Thank you in advance:) [/ QUOTE] Yeah, that coy Peugeot was pulling a pawn. I have a torque converter repair, the master is very cocky, no problem, but if your financial situation is good, buy a new convector is best.Normally torque converter repair, gearbox lowering, shredding collection and relocation (certain parts are irreversibly broken in it, special kit is also used from it) , transmission oil change etc. It kept about 1500. The vehicle remained at it for 2 days. If you get the original, not the repair of the torque converter, add about 700-800 rubles on top of it, the good job is to distribute the gearbox completely, and if there is another problem, it says that the parts have expired. Be careful if you are in the mainland alone, most transmissions do not correct peugeot transmissions properly, then there is always a problem. The master at the peugeot service recommended the place I had built, but the guy wasn't getting a hair off his nose.
08.05.2020 16:56 # 17
Mustafa Can
Thanks for your help, thank you very much for your help, Mustafa Bey, I bought the vehicle to ride, but I think I wouldn't think I would have encountered such big problems before I got on board.
08.05.2020 16:56 # 18
mustafah
[QUOTE = Mustafa Can] Thank you very much for your help, thank you very much, Mustafa Bey, I bought the vehicle to ride, but I think I wouldn't have thought that I would face such big problems before I go, Göral dada said that we need to open the Transmission to this problem. / QUOTE] This is not a problem specific to peugeot alone. The same problem happened in a Honda Civic automat of a friend I know. If you just bought the vehicle, talk to the dealer, investigate the legal ways, say that I am right on the face of the worst counterpart. In the second hand, there is no vehicle in this comfort. I saw what nonsensical problems that my acquaintances using corolla and focus, which not everyone can end up praising. They said they wouldn't stay on the road with Corolla, but we stayed in the city personally. It was the contactlessness of a cable going from the battery, but in my eyes it was over that day, it depends on how much the first users looked at the car. Personally, I know that my father walked like a pocket knife when he used a hawk for 15 years because he was really looking, as if he had grown in his hand Lastly, the peugeot services in Ankara are sending transmission repairs to places like my master. The best solution is to ask the masters of fully automatic transmission, not at the service.
08.05.2020 16:56 # 19
Mustafa Can
We bought the vehicle for 23.500 TL and we were thinking about getting a lpg 25 thousand TL gearbox. I think it will be on the road with the most corolla.
08.05.2020 16:56 # 20
tolga35
bro; if you bought the second-hand vehicle you bought without checking it, you are a pejo nap! As he said, these gearboxes are used in many brands.
so there are torque converters in many automatic vehicles.
& nbsp; & nbsp; first get a second hand (especially if it is automatic) from the service, or if you want to get information about the vehicle from a trusted
mechanic, if necessary, test the vehicle.
& nbsp; note; I wrote them because you said, `` I got it as soon as I got the car, '' maybe it was a little harsh
but the friend tells the pain, stay calm ...
Page : / 2
