I HAVE OUR OWN PIECE
08.05.2020 14:58 # 1
BUBU
MY VEHICLE AIR OIL FILTERS. I WILL REAR THE REAR AND I WANT TO REPLACE THE SPARK PLUGS CAN I MAKE IT MYself?
08.05.2020 14:58 # 2
mehmet1965
If you have a skill, why not, I will do most of my own heat, for example, two nights I changed the back wheel ball first, but I have some experience due to my profession.
08.05.2020 14:58 # 3
You can definitely change the air and the wiper yourself, but I don't know the others.
08.05.2020 14:58 # 4
tugrahan
air filter and wiper all right
the oil filter has a dismounting device.
even a mechanic in a really difficult area in my 306 is putting on the fiber and removing the motor protection
I also call the spark plugs no contamination because it is neither too tight nor loose, so it has a complete setting.
you also have the risk of damaging the teeth in the engine compartment if you do not realize that you have the risk of catching teeth while wearing
08.05.2020 14:58 # 5
selfat8
You took the back ball roughly
08.05.2020 14:58 # 6
I want it too, I want to fuck something myself but there is no courage Approve
08.05.2020 14:58 # 7
Ozgur
[QUOTE = tugrahan] air filter and wiper ok too
206 da is the same.
08.05.2020 14:58 # 8
I changed the spark plugs of my 307 car myself. It's not difficult, and I recommend you change it yourself. If you paid less attention, no problem. I think your vehicle is 307, I can help as much as I can. If you change the oil filter, you can tell me then I have it because :)
08.05.2020 14:58 # 9
BAHTIYAR
I do not know the spark plugs of the 307, but you can change the others. The oil filter is removed with a black palstic pliers-like tool that stands upright to the left of the manifold.
08.05.2020 14:58 # 10
ali oncu
air pollen filter is easily up to you for oil and others
08.05.2020 14:58 # 11
muratgulen07
Is your 2006 model your vehicle? I have recently changed it down, half of it down, half of the engine is down to change the master air filter of the engine ... it is so hard to say that this is the case.
08.05.2020 14:58 # 12
erk
Why would you like to replace the spark plug and oil filter yourself? If the vehicle is under warranty, you will fly the warranty anyway. No, if you are not under warranty, you will not pay too much in a good private service. These are simple craftsmanship of course to those who understand and are experienced ...
