I have no more than 307 lpg
08.05.2020 20:21 # 1
Mehmet92_27
Hello friends about 11 months ago 307 1.4 16v Fbr lpg was installed in my car, but it was like 70% has gone to the tuning when it was about to stop since the day it was installed, but after a while it was not certain, the brain was also in the gas of the vehicle. I was resetting the gasoline settings somewhere in the last place, it was like a cut.
08.05.2020 20:21 # 2
talip206
I wish I had never heard of frbr if you had it installed on a more familiar brand.
According to the consumer law, your product is guaranteed for two years. There is probably a mounting error. Take the vehicle and say, "Either fix it or disassemble it and give me my money back." Because the goods they sell are under the category of defective products. The laws are on your side. If you go knowingly and you press it a bit, the job is solved. talip206 2017-05-14 11:34:38
08.05.2020 20:21 # 3
Mehmet92_27
Unfortunately, we are confident that we know the people we know, and I am not going to do this kind of work anyway.
08.05.2020 20:21 # 4
Peugeot35
[QUOTE = Mehmet92_27] Hello friends about 11 months ago 307 1.4 16v vehicle has been fitted with Fbr lpg, but it was like to stop it when it was about to stop and it was 70% gone to the tuning but it is not obvious after a while chokes the brain in the vehicle, misunderstandings, kicks first I stopped working, it was like gas cuts as I went, I reset the gas settings in the last place, I did not have any trouble in gasoline, I did the LPG calibration from the beginning, but again, I put the LPG in the same place and I came to the degree of selling the car. QUOTE]
My teacher is away from knowing what the job is going on at this time. brings the familiar man wet lump dry.
your problem is either assembly error or incompatibility. In short, you need to prove this, so do routine maintenance of the vehicle without missing much money. Clean the throttle + clean the throttle, go back, he did not make any excuses for you. our cars are french cars, they sit like a screed when we attach parts and attachments that are not so unknown.
You have not looked at, finally wipe the wiring from the beginning to get a good lpg battery over the electrical connections especially.
08.05.2020 20:21 # 5
Mehmet92_27
You are very right, I had a one-to-one experience, I went to a different fbr dealer and he looked at it, he looked again, he did calibration again, no problem, then it is the same again.
08.05.2020 20:21 # 6
Mehmet92_27
The second dealer I went to tells me that there is a tire on the bottom of the injectors, then it can lose its old property, is there anything really
08.05.2020 20:21 # 7
Peugeot35
[QUOTE = Mehmet92_27] My second dealer says I have a tire on the bottom of the injectors, then it can lose its old-fashioned feature. Is there anything really like this [/ QUOTE]
Now, let me say that they produce something to shake from the beginning, as they talk a lot, they believe in themselves. I will give you clear results now you decide.
The first misfire problem is that of the spark plugs. even look in the coil.
The 2nd stops make the idling fluctuations from the MAP SENSOR because it is the part that measures the pressure, and have this part checked. otherwise, you will not have any adjustment, you will always have problems.
3. drowning, degassing, cutting off gas, etc. problems make from throttle, you can remove this part and clean it with lining spray.
If the 4th air is old, I recommend you change it.
have them checked, you will definitely feel that something is getting better. concentrate especially on the spark plug and map sensor.
08.05.2020 20:21 # 8
Oktkor
It was my first car 307.
The lpg`l. He was switching to gas in a few minutes from the first run. He would definitely stop if he came across the clutch or something during the transition to that gas. There was no problem afterwards. After a while, after working normally, I started beating myself on LPG because I didn't want it to stop. One day, we changed the pads, tie rod etc etc, then the car started to stop more. I closed the complete LPG event and started using gasoline again.
I went, the brain was reset. It was okay, we went around. I came home stopped.
Again we went to adjust the gas, the butterfly was cleaned. Fixed. I came home stopped.
I went, the throttle changed, it improved. I came home stopped.
I went.
I returned home on foot. :)
May Allah save you ...
08.05.2020 20:21 # 9
DOSTEFE
Sa. Precious LPG Peugeot users! 1.6 I would like to share my LPG experience with my 307 LPG vehicle. Maybe we will have a friend who benefits. Atiker brand LPG system is installed in my vehicle.
What I disliked most was the lit engine fault light. The problem was solved when installing LPG spark plugs from Bosch and the engine light no longer comes on.
I also noticed that when the LPG in the tank is low, the vehicle tends to stop. It stopped before when the LPG was full, especially when there was no full heating yet. With the suggestion made in a forum, I asked the master to increase the pressure a little more, which reduced the problem.
It can stop when getting up from the red light, especially in summer. It can cause trouble in stop-and-go traffic. If the place where the light is also on the uphill, the distress can be bigger. Because the vehicle does not react to LPG immediately, it can escape back quickly. I solve this by applying the lights handbrake, loading the gas well, and taking off in a controlled manner.
I have encountered a serious drop in traction in LPG before. The master said the ignition problem. I said no problem with gasoline. He said you can't feel it on gas. The problem was resolved by removing the spark plugs, removing and cleaning the coil and spark plugs. LPG immediately feels the slightest ignition error.
Accident-free trips for everyone ...
08.05.2020 20:21 # 10
sdttn
If there is a problem with gasoline, this situation is most likely to be caused by the manifold, there is a leak, hole in the manifold. They may have made a mistake when piercing the location of LPG injectors, they may have forgotten to plug in a vacuum line, connect the vehicle to the computer and observe the manifold pressure.
08.05.2020 20:21 # 11
Mehmet92_27
I do not worry about the gas, so I did not think it was a spark plug, we changed the map sensor, there was the same problem again, I understand that the old was intact, I show it back to my clean vehicle, but I have problems with the lpg in my lpg I am thinking of inserting the lpg and installing another boron kit but I am afraid that it will be the same again
08.05.2020 20:21 # 12
Mehmet92_27
There may be a minor ignition error, and I will take a look at it.
08.05.2020 20:21 # 13
Mehmet92_27
[QUOTE = sdttn] If there is a problem with gasoline, this situation is likely to be caused by the manifold, there is a leak, hole in the manifold. They may have made a mistake when piercing the location of LPG injectors, they may have forgotten to install a vacuum line, connect the vehicle to the computer and observe the manifold pressure. [/ QUOTE]
This may be what you say, I will take a look at it, but if there is another chance, lpg is over for me
08.05.2020 20:21 # 14
sdttn
[QUOTE = Mehmet92_27] [QUOTE = sdttn] If there is a problem with gasoline, this situation is likely to be caused by the manifold, there is a leak, hole in the manifold. They may have made a mistake when piercing the location of LPG injectors, they may have forgotten to install a vacuum line, connect the vehicle to the computer and observe the manifold pressure. [/ QUOTE]
This may be what you say, I will look at it, it will be solved, but if there is any more, lpg is over for me [/ QUOTE]
Please write the result here.
08.05.2020 20:21 # 15
siyah307
I had a similar problem, I changed the spark plugs, our master and we don't have any trouble right now, at least I recommend you to have a look at the spark plugs.
08.05.2020 20:21 # 16
betaser
Friends, I have been using the Zavolli LPG system for 6 years and none of these breakdowns have happened to me. I go every 2 years to change the filters and have their settings checked. My vehicle is used every day.
08.05.2020 20:21 # 17
Mehmet92_27
Yes, friends, the problem is 95% resolved. The spark plugs have changed, and the calibration has been done again from zero. The LPG program has not been stopped anymore, but there is a slight flick in idling.
08.05.2020 20:21 # 18
betaser
If the throat butterfly is cleaned and adapted, then this problem will be solved.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
