I HAVE LISTED LPG TO MY CAR AND THE FAULT LAMP WAS Ripped
08.05.2020 16:48 # 1
sosyete_60
I WAS I LIKE I WANT TO LIKE THE MASTER, I WANT I LIKE THE MASTER, I WAS I LIKE THE MASTER, I LIKE THE MASTER, I WAS LIKE THE MOTHER AND 130 MINIMUM SPEED, TO SAY THE SPEED AND THE SPEED TO THE NBSP; 206 2001 MODEL 1.6 16V. I DID NOT MAKE WHY YOU HAVE HELPED PLEASE HELP ME
08.05.2020 16:48 # 2
sosyete_60
HELP ME HELP ME
08.05.2020 16:48 # 3
Lpg, poor mixture error, antipollution fault comes across ... A common problem is especially in peugeots.It is not a very important problem, it is only annoying to see that fault lamp.
08.05.2020 16:48 # 4
sosyete_60
WHEN THEY EXTINGUISH THE FAULT LAMP ALWAYS REMOVE
08.05.2020 16:48 # 5
They have to make a very nice LPG setting, or it will come out.
08.05.2020 16:48 # 6
metin
Since the LPG setting is a bit low, especially at high revs, the fuel is low. If you open the setting a little, it will be improved. To adjust, you need to adjust it by pressing the fixed gas at 3000 rpm, not rolent.
08.05.2020 16:48 # 7
sosyete_60
FRIENDS ARE WAITING YOUR ALL COMMENTS AND INFORMATION ON THIS TOPIC & nbsp;
08.05.2020 16:48 # 8
sosyete_60
WHEN OIL IS NOT FROM FAKIR, I HAVE NO PROBLEM OR A PROBLEM ORGANIZED IN ORDER TO GO
08.05.2020 16:48 # 9
metin
[QUOTE = sosyete_60] WHICH DOES THERE ARE NO BREAKING PROBLEMS OR THERE IS NO BREAKING PROBLEM ORGANIZED IN OUR WORK [/ QUOTE]
if not, it means that the master couldn't assemble it like a man. The same fuel is not enough when the vehicle is going at high speeds and the malfunction lamp lights up because the adjustment is made in rolent. & Nbsp; / div>
Note: Please do not write your messages using capital letters.
08.05.2020 16:48 # 10
sosyete_60
Well, I used it all day long, I pushed the car so hard, and it did not burn, then I did speed, but I do not know when it goes 130 km after hours.
08.05.2020 16:48 # 11
metin
[QUOTE = sosyete_60] Well I used it normally all day long, I pushed the car so hard and it did not burn, I did speed but at the time, after 130 km speed, I don't know how it burns suddenly. br>
Don't worry. Then you can handle it with a beautiful setting. Also, try not to buy cheap and low quality gases from you. & Nbsp;
08.05.2020 16:48 # 12
sosyete_60
friends, the problem has been solved I have made a nice adjustment because the lpg setting is low, now thank you to the friends who helped the fireproof fault lamp
08.05.2020 16:48 # 13
zgr
[QUOTE = sosyete_60] friends have done the problem, I have done a nice setting made because the lpg setting is low, now I hope thank you to the friends who helped the fireproofing fault lamp [/ QUOTE]
& nbsp; I have had the same problem (I had a lot of trouble when I first burned (2001 206)) I have done. According to my observations, I usually burn when the gas is low in the tank, and I use the vehicle for gasoline for a while. then it goes out. I recommend that you only connect it to a computer if the light is on for a long time. ultimately malfunction lamp. Likewise, last summer I thought that it was burning from the gas and continued on the intercity road, I was able to reach the titer with a vehicle, one of the valves was barely, I was able to vibrate and vibrate. & nbsp;
meanwhile, I made the adjustment, I changed the lpg filter but after a while it burned again - It went out. still continues.
08.05.2020 16:48 # 14
peugeot22
You can buy gas from a different LPG station and try it as well.
206 of the cousin was doing it.
08.05.2020 16:48 # 15
Cmoss06
That lamp can light up now and then, it is not a normal thing, but it just causes boredom.
08.05.2020 16:48 # 16
okan4037
When my tank is low, the malfunction lamp goes out. I could not understand this situation & nbsp;
08.05.2020 16:48 # 17
erenoz
I have heard that there is a frequently encountered lpg error in peugeot. Even if you delete the malfunction in the service, you may see it again. Make sure it's from LPG then try not to see it
08.05.2020 16:48 # 18
sosyete_60
oh if we can try not to see a bidet, oh it's a border breaking event
08.05.2020 16:48 # 19
metin
[QUOTE = sosyete_60] friends, the problem is solved. I made a nice setting that the LPG setting is low, so thank you to the friends who helped the fireproof fault lamp [/ QUOTE]
Thank you. I'm glad it's done.
08.05.2020 16:48 # 20
metin
[QUOTE = erenous] I have heard that there is a frequently encountered lpg error in peugeot. Even if you delete the malfunction in the service, you may see it again. Make sure it is from LPG then try not to see it. [/ QUOTE]
It's not a common thing, I want to fix this. This is something that is entirely because of the bad master. I made it to the master of his work. I have used more than 30,000 km of lpg for 2 years and it did not light up the malfunction lamp once.
therefore, if the man is not a master, if you wear even the best quality lpg system, it will run without efficiency.
Page : / 2
