I have a lot of problems with my newly bought 307
08.05.2020 17:48 # 1
murateest
Hi friends 2 days ago I bought 2005 model 1.4 hdi xr 307.
The first thing that caught my eye was that the second stage of the ventilation switch was not working.
I tried quite a lot, but eventually I found the resistor, the problem was with the cables.
So this problem was resolved.
If those who have the same problem remain, I can tell.
Secondly, the temperature of the vehicle increased to 100 degrees.
I connected it to the computer, and the cooling fan had the 1st stage not working fault code.
In this problem, I got out of the fan resistor again, and I changed it, and this problem has been fixed.
When I look at it from the last computer, it turns on the fan at 96-98 degrees and turns off at 93 degrees. How are the situations?
Now my remaining problems;
1- They connected the rear wiper water to the front wiper water. I removed the bumper and looked at the engine, there are two outlets, one of them was canceled and the other one was t and they attached it to the hose that went to the back.
However, when I open the rear window sprinkler on the wiper arm, there is no engine noise.
I looked through the booklet, the rear and windshield sprinkler fuse is common, so it is impossible to be there.
Does anyone have experience with this?
2- The opening and closing keys of my original remote key do not work.
When I bought it, I changed the battery was exhausted, the button was broken, I changed them too, it seems to function when I measure the controller, but I could not associate it with the car in any way.
I tried all the instructions.
3- They took out the original tape of the vehicle and installed a usb-branded Jameson tape, although the tape is nice, I feel dissatisfied with the non-original stuff, so anybody want to sell the original tape?
I tried last night, follow me home feature is available in the car, are there other features like this?
For example, do open windows close with the key? or with the remote?
Thank you in advance for your help.
08.05.2020 17:48 # 2
murateest
If I opened the issue to the wrong place, I would ask for it to be moved.
08.05.2020 17:48 # 3
error
First of all, your vehicle is good, the problem is not always bad, it forces the person to get to know the vehicle and the vehicle will give you a kind of education. LOL
Let me try to answer your problems starting from the end:
*** You can find an original CD tape for your car, but for now, don't waste your time, handle it with a bit more on it. After some time, you will need to replace the sound system with a man-like system, and then it will not cut you in the original tape.
** If you have the original key, a unlocking will solve your problem with a simple operation or, at worst, coding.
* the problem seems to be on your wiper arm if there is an oxidation in your sprinkler switch, there will be no energy to the wiper motor.
as a result, if you have trouble walking and chassis These are minor possible problems that can be resolved over time, but it is always useful to find a master who knows the vehicle.
without accident, without penalty ....
error 2013-07-19 23:57:19
08.05.2020 17:48 # 4
dream
First of all, welcome to us and have a good vehicle. I think all of you mentioned are minor problems, but it seems like your vehicle has been used a little contemptuous or tired by someone who does not appreciate your property.
08.05.2020 17:48 # 5
Serkan
The water sprinkler motor works bidirectionally, disassemble the water sprinkler motor, check whether there is electricity in the socket when you give water to the rear window.
08.05.2020 17:48 # 6
murateest
Thanks for your answers.
I do not bother myself because of the problems, but I like to deal with every vehicle I buy.
It was wise to get help from you just because I couldn't solve some of them.
There are 2 cables entering the sprinkler motor, so in this case, if it runs left and right, it can send water from separate outlets to the rear and front.
In this case, could the right part of the engine be working, but the left part not working?
It seemed to me that the wiper arm was more likely.
I'll measure and check it today.
08.05.2020 17:48 # 7
Serkan
`` In this case, the right part of the engine works, but the left part might not work? ''
Unfortunately, I do not know the answer to this question, I think that one side will not be spoiled, but I do not have technical knowledge.
If you find out that the key code is not connected to the service, some services may charge 20-30 TL. Actually, the code is given with a credit card along with the vehicle, but the users do not claim much, I kept the key code card of my 2004 model vehicle I sold 15 days ago without losing it.
08.05.2020 17:48 # 8
qqyyxx
how much did you get this vehicle?
08.05.2020 17:48 # 9
murateest
I took off the engine and looked at the wiper arm.
The problem was in the junk at the end of the engine, there was a gasket and a plastic wipe inside which it was inserted, this plastic should be enlarged over time or thickened due to the residue that it did not move inside the rubbish.
So it could not work right and left could work.
It actually works, but because of the jam, the sound of the engine is too low to be heard.
I bought the vehicle for 15,000 TL without inspection. (It costs 250 TL for inspection.)
08.05.2020 17:48 # 10
murateest
By the way I am looking for the cruise control arm Beer
08.05.2020 17:48 # 11
dahi
If you have changed the battery of the key, it is necessary to introduce it, I do not remember exactly, but it was set by using the contact and glass download keys, but I do not remember if you want a search from google
The cruise control arm is sold on most peugeot parts, I would recommend the net and reele minister.
Looking at the price of the vehicle, it looks like a maintenance-free first air flow meter theory may have suggested that I recommend you to clean it with oil-free contact spray, both fuel and traction will change noticeably, you can apply repairs by looking at the net.
Good luck to your vehicle. even 2013-07-21 04:12:12
08.05.2020 17:48 # 12
murateest
[QUOTE = even] If you have changed the battery of the key, it is necessary to introduce it, I do not remember exactly, but it was adjusted from the contact and glass download keys, but I do not remember, if you want a search from google
Good luck to your vehicle. [/ QUOTE]
My teacher says in the vehicle's booklet, "Switch off the ignition - switch on the ignition again - press button a immediately - switch off the ignition" and the switch will work again.
I tried this, there is another one written on the net, I tried it too, but I could not find what was done with the glass key.
I couldn't find the arm price under 100 TL.
How much does the authorized service charge for activation? (Cc)
Yes, my car was very neglected, but I think it was a good deal.
I have heard that the flow meter is a very sensitive device and does not come into hands.
But if you are sure about this, I will clean it with a sponge liner.
In the meantime, fuel and traction sounded good to me, but what if he gets better.
08.05.2020 17:48 # 13
murateest
I made the control and gave 20 TL.
The master who made it said that I changed the chip is broken :)
However, I looked at both the chip and the crystal, so that I could find out what was broken, I looked after the master's job, the chip was the same in the crystal, so it did not change anything.
I think there is oxidation under the chip, it may have removed it and cleaned the gold.
By the way, these controllers have slim type 3v batteries.
And it keeps saying low battery all the time.
So I replaced it with the thickest type 3v with high amps.
Of course, it is necessary to upgrade the slot according to the battery.
I mean the metal that holds the battery. The thick battery fits in the box of the controller without any adaptation.
In the meantime, one last thing, I realized today that the rear brakes of my vehicle or the handbrake are stuck a little bit, when I try to go forward, the back of the vehicle is sitting, when I try to go back, the rear of the vehicle goes up.
Has anyone faced a problem like this a chronic thing? Or will I be able to handle it with a simple brake adjustment?
