I have a key problem in 306
08.05.2020 15:08 # 1
hhuzun
hello to everyone. my friends have my 306 200 modl hdi sw
1. I turn off the automatic lock again. I brought him to the repair shop
all the doors got stuck, he didn't find anything.
Automatic side mirrors do not work in the 2nd problem
I made it look
Usata said that the auto-rotary lever may have been worn ... Confused
I WOULD LIKE YOU TO HELP THIS TWO TOPICS. SELAMAR FROM FR FROM EVERYONE ...
WHERE ARE THE MASTERS OF MY MUMLEKET HERE?
08.05.2020 15:08 # 2
I experienced such a problem in myself. There is rust and no contact in the sockets on the doors. Because of this, doors, windows, mirrors, etc. may not work ... the cecol 2011-03-05 13:50:45
08.05.2020 15:08 # 3
hhuzun
SAGOLASIN FROM MY FRIEND. I LIKE THE SOCKETS OF THE DOORS, BUT THE SAME. WHAT SIDE MIRROR CALISIYO WHAT I DID NOT UNDERSTAND THE LOCK. WHEN THE REPAIRERS DO NOT UNDERSTAND THIS CAR, THEY ARE SAYING THE DISEASE AND PREVIOUSLY.
I would love if you explain the solution way more openly
08.05.2020 15:08 # 4
First of all, you will insert the 2 bolts on the pole of the handle holding the door, so that the door can hurt until the end.
When the door is opened, the cables coming out of the case enter the door with an external socket. you will open that socket.
If you have a small mirror next to it, you cannot see the inside of the socket and you will see it with a mirror. If there is kuf rust inside, you will clean with rust remover and contact sprays (wd40, contact spray etc.).
then you will look at the cable side and do the same maintenance.
you may be checking the slope of male plugs, it may not touch the outside.
Then you will press the socket well with one hand and tighten it to the end without any teeth.
open the door close the door close you will control. if you need, you can wrap a part of the socket with a quality cloth tape. Because water may be ticking in, but before you wrap it with tape, you should clean the outside of the socket from the grease from the ground, or you can grab the tape with a little silicon.
Finally, you will install the bolts of the handle of the door and let it heat.
If this contactlessness occurs, the car can open its doors to itself ... when it is not contacted, it can hurt on its own when the doors are locked, as if the doors are hurt again. this situation is very stupid, but it was like me as well: ((((
I hope I could explain ...
08.05.2020 15:08 # 5
hhuzun
SAGOLAS, MY FRIEND WILL DO WHAT IS INSALLAH. INSALLAH SORUN COZULUR
