I had 307sw maintenance.
08.05.2020 18:00 # 1
albayman
70bin km 2005 307sw 1.6 lpg following parts and prices
oil filter: ________ 15tl
air filter: _______ 20tl
pollen filter: _______ 20tl (carbonless)
4 spark plugs: ___________ 50tl
hydraulic oil: ______ 10tl
alternator belt: ___ 20tl
Tension roller: _____ 20tl
mobil 10-40 oil: ___ 80tl (5lt)
lining spray: ______ 10tl
labor: ____________ 60TL
Total: __________ 300tl
parts are original brand products used by peugeot.
I am open to your comments about prices.
Does the carbonless pollen filter to digital air conditioner have any inconvenience?
*** While the engine is idling, a groaning sound comes from the alternator belt. It sounds like a ringing sound, not a steering pump sound, but a different sound. the sound stops when the alternator belt is removed. we replaced the belt and the bearing, but the sound did not stop. Air conditioning and alternator bearing balls are left. I have turned the bearing of both the alternator and the air conditioner after the belt came out, no jamming is difficult, no turning, it turns comfortably. do you think it is necessary to change ball bearings for this sound? Is there any possibility of trouble if we don't change?
08.05.2020 18:00 # 2
samet206
Good luck, the price is normal bye. How a sound these cooker lighters are like a snap, I have a silent sound, I have a completely different problem and there is no connection with the strap.
08.05.2020 18:00 # 3
albayman
It's not cracking. Like a continuous groan in the form of viiiiyyyjjjjjjjjjjjj. It sounds like a lot of keys are constantly swinging on a key ring. cut off the alternator belt. I think it is in either an alternator or air conditioner compressor bearing.
08.05.2020 18:00 # 4
samet206
[QUOTE = colonel] is not a snap. Like a continuous groan in the form of viiiiyyyjjjjjjjjjjjj. It sounds like a lot of keys are constantly swinging on a key ring. cut off the alternator belt. I think it is in either an alternator or air conditioner compressor bearing.
If the v-belt was cut when it was removed, it may be in another piece of electronics or it may be in the v-belt.
08.05.2020 18:00 # 5
I had a similar problem. The pulley with the V-belt has changed and the problem has been solved.
