I got my insurance taken off, urgent please |
| 08.05.2020 20:47 | # 1 |
| 08.05.2020 20:47 | # 2 |
ggitaristt |
Do not be afraid I did it .. The same happened in 307 .. The location is probably not the same, but the brain and the fuse of the screen are the same. If you want a spot, you will wait for the 206th. ![]() |
| 08.05.2020 20:47 | # 3 |
[QUOTE = ggitaristt] Do not be afraid I did it on me .. The same happened in 307 .. The location is probably not the same, but the brain and the fuse of the screen are the same. If you want a spot, you will wait for the 206th. ![]() [/ QUOTE] I looked at the fuses in the engine, obviously I couldn't see a darker, you changed my 10 amps |
| 08.05.2020 20:47 | # 4 |
guncel
| 08.05.2020 20:47 | # 5 |
ggitaristt |
[QUOTE = emresensoy307] [QUOTE = ggitaristt] I did it on me don't be afraid .. The same happened in 307 .. The location is probably not the same, but the brain and the fuse of the screen are the same. If you want a spot, you will wait for the 206th. ![]() [/ QUOTE] I looked at the fuses in the engine, obviously I couldn't see a darker, you changed 10 amps [/ QUOTE] It was a 20A yellow small size fuse in the fuse box below the steering wheel. |
| 08.05.2020 20:47 | # 6 |
[QUOTE = ggitaristt] [QUOTE = emresensoy307] [QUOTE = ggitaristt] I did it, don't be afraid .. The same happened in 307 .. The location is probably not the same, but the brain and the fuse of the screen are the same. If you want a spot, you will wait for the 206th. ![]() [/ QUOTE] I looked at the fuses in the engine, obviously I couldn't see a darker, you changed 10 amps [/ QUOTE] It was a 20A yellow small size fuse in the fuse box below the steering wheel. [/ QUOTE] we have a lot of work with the engine contents then |
| 08.05.2020 20:47 | # 7 |
[QUOTE = ggitaristt] [QUOTE = emresensoy307] [QUOTE = ggitaristt] I did it, don't be afraid .. The same happened in 307 .. The location is probably not the same, but the brain and the fuse of the screen are the same. If you want a spot, you will wait for the 206th. ![]() [/ QUOTE] I looked at the fuses in the engine, obviously I couldn't see a darker, you changed 10 amps [/ QUOTE] It was a 20A yellow small size fuse in the fuse box below the steering wheel. [/ QUOTE] 20 amps under the wheel according to the scheme in me |
| 08.05.2020 20:47 | # 8 |
ggitaristt |
Aga, you take it out in order to check it out. |
| 08.05.2020 20:47 | # 9 |
[QUOTE = ggitaristt] Aga you check it out in order .. I don't think there is too much insurance in the 206's .. [/ Quuot A] I'm at work now when I leave, I will see the vehicle 307 |
| 08.05.2020 20:47 | # 10 |
ggitaristt |
| 08.05.2020 20:47 | # 11 |
