I got 307 automatic LPG gasoline needle falling
08.05.2020 19:37 # 1
gngr
When I asked the master if I had a new LPG gasoline drop, these are the computerized system.
08.05.2020 19:37 # 2
and
Here is another one :)
08.05.2020 19:37 # 3
gngr
Eyvan. I mean, chronic, tsk.
08.05.2020 19:37 # 4
usta307
Normal contact is not always when it is awkwardly closed but then it rises to its old level
08.05.2020 19:37 # 5
yes, this is a problem with most lpg li french vehicles. You will either go to lpg c and install the psa module or you will try not to drop the gasoline under the half tank so that the gas gauge will reset itself at certain times.
08.05.2020 19:37 # 6
selim38
Hello.I own 307 tiptronic 6 months ago, I am glad that I had psa module, I recommend it, at the same time, I also installed a gas cutter, when the car passes to LPG, it stops the operation of the gas pump, which prolongs the life of the pump. selim38 2016-01-24 20:13:25
08.05.2020 19:37 # 7
turgay307
Do not drop it under the half tank, it is the most logical one
