I got 206 help on some issues ...
08.05.2020 16:36 # 1
C@GL@R
hello everyone step ages two days ago 2005 model 43 bn km I bought 1.4 206 x-line.
1-airbag lamp on the authorized service computer tied up the seat belt, it is necessary to check the defective cables, he said, what is the cost?
2-1.4 my vehicle is on the long road and the average light burns the vehicle 75 horsepower km 43 thousand more full maintenance
I will buy a tire on a 3-vehicle with a steel rim, 15 inches. What do you think should be? It takes a lot of road noise. There is no brain left in the vehicle. how do I get myself changed?
these are the things that come to my mind for now, there is not much equipment available :)
08.05.2020 16:36 # 2
C@GL@R
20 people who have looked at the servant of a god did not write cvp, I think the forum is not very active :)
08.05.2020 16:36 # 3
The forum is very active.
Those who do not introduce themselves are not answered much and are expected to introduce them first. If you want, first of all, you should get a link to the water link. Your questions are not going to be answered anyway "Smile"
08.05.2020 16:36 # 4
C@GL@R
This is not my first position, I opened a topic saying that I was going to buy a car before.
08.05.2020 16:36 # 5
omer_tarsus
2- It burns around 35 krş in the city
3- 185 - 55 r15
4- estimated about 300
There is nothing I can say for 1 and 5, others are my opinion
08.05.2020 16:36 # 6
C@GL@R
thanks..
08.05.2020 16:36 # 7
nurinuri58
1. I do not know
It burns a lot since the 2nd car has 15 rims. I have the same in me, lpg li 186 kuruş city. Between 200kr city burns.
3. the original size is 175e65 r14. The car, which has lost its suspension system since it is sninki 15, is very bulky. and it sounds very loud. I had a 205 to 40 r16 inch rim, it was like a horse-drawn carriage. last year I had the master in the industry oil spark plug filter and tiriger all 300e. but it came to my inexperience now I can get it cheaper.
5. I just changed it over the weekend. open your luggage. On the side of the lamps, there is a plastic round screw-like staple and a screwdriver. Grab the carpet floor by its end. face a spongy lid and remove it. There is a plastic nut holding the lamp. The cable is freed from the tab and comes to a stop. then you get the sensation that there are three lamps on the nails & nbsp; open the back. When you press and rotate, & nbsp; the lamp will come out. Yours sincerely. IF THE TIRE TIRES ARE IN GOOD CONDITION. & Nbsp;
08.05.2020 16:36 # 8
C@GL@R
Thanks for the answer, I bought 100 lira of gasoline, I traveled 120 km long, I went 30 km. I went to the hand, a little dropped. The interior was burning at 30-35 krş lpg so I guess it won't put the fuel on me too much :) I will get bad tires tomorrow. There are 185-55-15 on it but I think it will be a more comfortable ride if I get 185 65-15. timing never changed tool 7 years old 43 thousand I think I have to change the timing of the tire, first thing is the tire then the timing ..
Can you give me information about this vehicle, do you have an immobilizer? @R 2012-02-22 20:29:28
08.05.2020 16:36 # 9
KenBlockJR
No 185-65-15. 185-55-15, 195-55-15, 195-50-15. Even 185-60-15 there is the possibility of rubbing taxa. my suggestion is 195-55-15.
08.05.2020 16:36 # 10
C@GL@R
only the thickness of the cheek will increase by 1 cm.
08.05.2020 16:36 # 11
KenBlockJR
The diameter of the tire increases by 4-5cm, which causes the steering wheel to be left and right and rubbing into the mudguards when many people sit behind. Also the clock runs incorrectly. When it shows 100, its actual speed is 107km. etc. etc. a lot of negativity. 185/55/15 is the same diameter as the original size.
08.05.2020 16:36 # 12
C@GL@R
then there is no choice but to take 185-55-15: (& nbsp; thanks ..
08.05.2020 16:36 # 13
black_rock
Use your car with a laugh, I wish you an accident-free ride.
I have a 2004 model x-line. .
& nbsp; & Nbsp; Good luck again ..
08.05.2020 16:36 # 14
ekinoks44
In the authorized service, the timing change should be 300 TL.
08.05.2020 16:36 # 15
C@GL@R
[QUOTE = black_rock] Use your car by laughing, I wish you an accident-free ride.
I have the 2004 model x-line, I bought 185-55-15 tires, I think there is no fuel consumption, I changed the trigier set when I first received the car. cost in service was 175.00 pounds.
thank you. Let's take a tire first, then I'll change the set right away. If 175 lira is good, is there a site I can get from the net link etc. I want to buy myself from the net with a credit card and give the master only workmanship ..
08.05.2020 16:36 # 16
nurinuri58
There are what they say immobilayzer .. I made it 2 3 weeks ago, said uncontrolled 75 and accepted 40tl kayseri li. respects.
08.05.2020 16:36 # 17
GiTaRRa
in the main total, there are wheels including timers, tires, etc.
