I got 206 confused
08.05.2020 19:57 # 1
alicelik20
Hello friends. About a week ago I bought a 2005 model 206 from my father's military friend. In expertise, the engine performance of the vehicle came to 99% and paint in 4 parts. The seller did not know which expertise I would go to and I kept the friend outside until I received the reports . But they still said that I would take it to a peugeot service and have it looked again. In short, I took this tool for 25 thousand liras. I write the ones that stuck in my head, respectively. Smile
* Do you think I did it right to give this vehicle 25 thousand?
* EBA, EBD and EBV are available in my car as an option. How can I tell which of them are in my car?
* My vehicle does not make more than 170 on LPG. My old vehicle was making 200 born tofas. 170 is normal for this vehicle. (I go to these speeds just to try. I usually don't go over 100.)
08.05.2020 19:57 # 2
canbicerr
My teacher, first of all,
I have 2000 Model 206 1.4 XR model, I see 200 with the vehicle lpg. I think a 2005 model should see it even more comfortable.
08.05.2020 19:57 # 3
alicelik20
The printing pad needs to be replaced. I will not take care of him on Tuesday, I will try again. I think he should see 200 comfortably.
08.05.2020 19:57 # 4
KILIC
best wishes. May Allah not cause any trouble, the engine was not a bit too 99% if it was like confusing your mind. No problem with that test.
08.05.2020 19:57 # 5
alicelik20
The expert in charge has some margin of error. "You look 94%," he said. Then I took it to a Peugeot service, said the master engine, there is no problem. I did not force much after that time, I bought the vehicle.
08.05.2020 19:57 # 6
Bha41
May your vehicle be good. Is it the first owner? If the history of the vehicle, etc. is known, I would consider giving 1 2 thousand more according to the market.
08.05.2020 19:57 # 7
alicelik20
There is nothing to be done in the vehicle, except for the visible pad. There are a few scratches, but I don't mind much. The engine that messes with my head doesn't feel like a really good acceleration or 1.4, but why does its maximum speed remain low. The first two options, the road I tried the vehicle is not flat, but bumpy, there are bends and bends. I'll have the printing pad tomorrow. Then I did not try again, I try the bidet straight on the road.
08.05.2020 19:57 # 8
alicelik20
I haven't tried the km at all, but when I go to the station and get lpg in the city, I get a lot of funny figures like 8 lira and 10 lira. I took the last 3 days and got 12 lira. It burns less than enough. I will also try fuel tomorrow, I will write the last situation under this topic. Thumbs Up
