I go to 100 thousand maintenance (307)
08.05.2020 17:41 # 1
Mortal_Abas
Hello
I bring my 307 2004 model automatic gearbox to 100 thousand maintenance, this time I will have a master in the industry, not the authorized service.
Thanks to my friend cerci07, I learned that I should get the following for the maintenance period
1- oil filter, air filter, pollen filter
2- spark plugs
3- brake fluid
4- engine oil
I have a few questions
1- What is the crankcase plug gasket do I need to change?
2- For this time, total quartz 7000 10W / 40 has been installed for engine oil, but castrol edge 5W / 40 is fully synthetic.
3- When the car exceeds 120, there is a sound on the steering wheel such as tremor and vuuu. Does this sound come if the wheel is crooked, and when it goes from winter to summer tire, balance was made or nothing else. What else can I look for in this tremor and sound?
08.05.2020 17:41 # 2
samet206
If the tremor is skewed on the rim, it will do so because I had it in my car, I changed it on the right front rim, there was no problem, and if you can fix it, it is not necessary to change the pulsed rims, besides, if the tire structure defects have occurred, the room may cause tremor, the balance should be done in a healthy way, of course, the new generation computerized system rather than the old type ones. The sound of humming may be caused by the tires. When you say the card stopper seal, I think you are talking about the gasket on the top cover of the engine that surrounds the engine block. I can recommend 5W / 40, but I do not know why you want to change the brake fluid but of course not I am not saying that it is not very good, but besides this, I can advise you to give priority to your gearbox oil since your vehicle is an automatic gear, if any change control before, etc. If you have not been to the incident.
samet206 2013-06-10 15:09:43
08.05.2020 17:41 # 3
Mortal_Abas
I took a picture of the equipment I bought is there anything missing? the gasket on the air filter got the tarter plug gasket right? A rubber gasket came next to the oil filter, what is it? I did not put all 4 of the spark plugs.
For the brake fluid of samet206, it is necessary to change every 2 years during the maintenance periods given by our surgeon friend.
08.05.2020 17:41 # 4
Mortal_Abas
By the way, the transmission oil has never changed before, but I do not need to change it, my gear changes are fine. I do not want to play with the gearbox, I usually read it as if they smear their eyes
08.05.2020 17:41 # 5
mami202
One of your trembling wheels is caused by a trapezoid lap. If you want the transmission to work without any problems after 40000 km of automatic transmission, I suggest you to change the oil of the transmission in a quality place. The oil change is preventing the gearbox overhaul, which is largely burdensome in the future. respects..
08.05.2020 17:41 # 6
error
If you take into account your mileage, I would like to have your rods checked, I might be concerned with the tremor and wear of the sound tie rods ...
08.05.2020 17:41 # 7
Gokhan Cetin
[QUOTE = mortal_abas]
what is fiat teacher
08.05.2020 17:41 # 8
Mortal_Abas
pollen, air, oil filter, 4 spark plugs, gasket, brake fluid 500ml total = 128 pounds
4 liters of castrol oil = 90 TL
How can I tell if the oil is original?
I plan to sell the vehicle without 120,000 km, so I do not think of getting involved in the gearbox business. Let's start in the morning. thanks for everything friends
08.05.2020 17:41 # 9
Mortal_Abas
hee meanwhile, I just renewed the front tool members such as tie rod tie rod hanger rod
08.05.2020 17:41 # 10
samet206
The valve that I was talking about was the top cover gasket, I got it wrong, it's okay if you want the product you want, the gasket of the right oil cap is okay. But if you say why don't you be afraid about the gearbox oil, your vehicle will not be tampered with unnecessarily. It saves lives.If you do the necessary research as in this matter, I think you will reach healthy information regarding that subject ...
08.05.2020 17:41 # 11
Mortal_Abas
I had it done today absolutely and definitely, 5w40 oil has reduced the noise of the engine, the vehicle is running less noisy than before, but my master says it is not from oil but from the air filter. I put the brake fluid on the master, I did not need to change it. As I said I have never looked at the gearbox oil, I am thinking of selling the vehicle without 120 000.
After 120, he checked the rear balls for the humming sound while the car was on the lift. The right back ball said it was problematic. By the way, you forgot to tell the master, there was a metal rubbing sound when you parked the vehicle, while maneuvering left and right.
08.05.2020 17:41 # 12
Mortal_Abas
My master changed the right back ball today and the sound was cut off. Now I made a very quiet vehicle. 120 150 170. No good sound. No sound. The metal rubbing sound still continues, I have always been doing it for 4 months. I have always heard it while parking like this for 4 months. My master has checked everything but for a reason he could not continue for now. Thanks for everyone.
08.05.2020 17:41 # 13
nevce
My teacher said I need to change the hydraulic oil in the maintenance changed 65 TL :) get the news by the way, where did you get these filters? What is the price of the oil?
08.05.2020 17:41 # 14
Mortal_Abas
where did you get it done only workmanship 65 or brake oil included?
bought my parts from the authorized service oil 90 lira from a familiar car wash
08.05.2020 17:41 # 15
emre_akdag
Good luck auspicious :)
08.05.2020 17:41 # 16
jiyanxese
Which oil to use 307 1.6 lpg 5w 40?
