I EMERGENCY EMERGENCY
08.05.2020 17:12 # 1
sukur
Friends S.aleyküm. Good forums everyone. My problem is this: The day when I said "The heating of my vehicle is my favorite feature", the heater that warms it like an oven suddenly started not heating. The reactions I noticed when I got there for a few days to identify the problem are:
When the vehicle is idling and cruising (even if revving), it blows cold unless it presses the gas. It gets a little warm when I press the gas, but it's still not what I used to be. When you touch my hand to the radiator under the console or if you call it, I realize that it is hot.
What do you think I am and what is the solution?
My car LPG 2000 model automatic 1.4 - 206
08.05.2020 17:12 # 2
extremex16
If the heating system of the vehicle is manual or automatic, there is a problem in the control levers.
08.05.2020 17:12 # 3
sukur
how much is his expense
08.05.2020 17:12 # 4
Alicilik
I usually heard it in the 307s, but it can happen in the 206s. There is an electrical part for heating inside this panel. At that time it was deformed and even a few people had the same problem and easily solved the problem with a 5TL piece. I don't remember exactly who did it, when I did it, but I know that it exists in the forum.
08.05.2020 17:12 # 5
Serkan
Sir, my cousin had a similar situation in kango, there was no problem, when he got up in the morning, the heating was not warming up the boarded vehicle, 3-4 hours in the frozen vehicle, the next day went to the industry, the heater honey was plugged, they opened it with a bottle of porch.
08.05.2020 17:12 # 6
There may be several reasons.
1. Check the level of the coolant, if missing, determine if there is any leakage,
2. If 1 is ok, check for air in the system,
3. If all 2 is OK and you are not using antifreeze coolant in your vehicle, check / have the circulation pump installed.
koliva 2012-12-11 21:32:18
08.05.2020 17:12 # 7
feline
digital & nbsp; or analog?
08.05.2020 17:12 # 8
sukur
SOLVED: I'm saying with embarrassment of friends. My car is running out of water. I know how long I've been using it. When I opened it, it was dry. I was amazed at how the car did not run at all. I didn't want to put water on it myself to make it air or open it, but it was a lesson for me. Always check after that. Thank you all
08.05.2020 17:12 # 9
hsnsnl
Are you going to burn the lion?
08.05.2020 17:12 # 10
ByHack
Do not worry, your vehicle will not air by opening the cover of the coolant tank. Soundly...
