I don't know about my 307 sw pack tool help ...
08.05.2020 16:23 # 1
albayman
Hello everyone. I'm new to the forum. I wrote to the dating section.
I bought a 2005 model 307 sw pack 1.6 16v lpg panoramic roof & nbsp; vehicle. Authorized service such as brand-manager :) at 40 thousand km. I paid a little bit more money, but I was so silent ...
& nbsp;
routine. (oil, oil-air-pollen filter & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; lpg filters and setting.)
& nbsp;
but I don't know my car's equipment.
< DIV> asr esp eps abs or something and I do not know which ones are available. I don't like the authorized service money trap.
& nbsp;
1. When I put on the throttle in gear, it sounded like the clutch is missing. & nbsp; & nbsp; While I'm driving the test, I'm not sure how it could be in the antipathy system. the light did not come on. Indicators. > 1.) How can I get information about the features and equipment of my vehicle.
& nbsp;
2.) The original tires on the tire are good, but is it necessary to replace them after 7 years? Should the timing change? Maintenance and replacing parts must be replaced when the part that is ready for timing is removed.
& nbsp;
3.) gives airbag error. they said it was corrected through the left signal arm. What is the cost? who has experience ?,
& nbsp;
4.) I did track cd, how can we play it?
& nbsp;
about the tricks of the vehicle I can get comments from those who have information.
& nbsp;
thanks in advance.
albayman 2011-11-23 22 : 08: 24
08.05.2020 16:23 # 2
yavuz25
1-) If there is an anti skid system, the lamp flashes on the display to show that the car is intervening. What caused the feeling that the clutch missed? The timing I know varies according to & nbsp; km as you approached. & Nbsp;
1-) You can access all the information of the vehicle by reading the user manual. I personally did so. :)
2-) It is a very long time for a tire for 7 years. It threatens you and those in the car at all times for safety.;) I recommend you to change it as soon as possible.
3-) The airbag is a vital I recommend you to consult this service, as it is important.
4-) If you give more detailed information, we can answer more clearly .;)
yavuz25 2011-11 -22 15:43:11
08.05.2020 16:23 # 3
droprain72
Hello my friend, the tires on the vehicle are about 6 years old. Even if the tires do not wear out in 6 years, it will be useful for you to replace them.
The timing change is every 5 years or an average of 80,000 km. When changing, the complete set will change the V-belt and the circulation pump. This means an average of 350-450 TL. napalım
you may have used it in the snow mode you call antipatinaj in the vehicle, but it should not shout. God bless you to use it.
regards ...
08.05.2020 16:23 # 4
albayman
Thank you very much for the answers. I was surprised that it came really fast :)
& nbsp;
I hope it was an accident-free day ...,
& nbsp;
then the industry road appeared to us:) < / DIV>
& nbsp;
When I connect it to the computer (p2000), I think we can see all the equipment the vehicle has. though it was the fullest tool of the date it was sold, but I do not know how to use the CD changer of the 5D CD changer. I did not read a track cd with nero at home. sometimes he didn't give it back. I will learn now. Nero has a lot of features, which one to do and what to do is also hard to understand.
says load cd 1, nothing plays ... then turns to the radio. I press the src key, first a silence, then turn back to the radio ...,
& nbsp;
the clutch is as follows: while lifting it in 1st gear, the engine speed is 4000e but we did not experience the same rapid takeoff in the vehicle. the vehicle was very quiet. as if he's missing a clutch. already grasps a little above.
& nbsp;
the airbag error was fixed to a figure of 100 TL but it had 2 3 hours of work.
& nbsp;
< DIV> vehicle's owner's manual is not available. I always looked at the pug website, it's history. my vehicle was released in april 2005. I do not know if the guide presented on the site in this date range is suitable for my vehicle.
& nbsp;
I am slowly learning now ...
08.05.2020 16:23 # 5
droprain72
hi again
my friend, first of all, you need to write to the lowest speed and quality blank cd while doing track cd. the speed should be 8-16X. The device that I call airbag line will be explained to you automatically. If you have any other questions you want to ask, you can write without hesitation.
08.05.2020 16:23 # 6
felusdomesticus
If you make a track cd using the "BURN" feature of the windows media player, you won't have a problem.
08.05.2020 16:23 # 7
albayman
thanks.
& nbsp;
I guess I forgot to specify this 5-speed manual gear.
& nbsp;
about cd: after plugging cd into cd changer sounds. First, that cd light is blinking, then all the lights are blinking completely, not giving the cd. After a few hours, when I started the car, he gives the CD out according to his pleasure, but I couldn't listen to the & nbsp; cd ...
& nbsp;
Let's try the bidet windows media player ...
& nbsp;
by the way, the car is very beautiful, it gets better as we get on it. It is very unclear whether it works from outside or inside. exhaust also from its original quiet. I hardly like the car that shouts headaches. the interior is quite spacious. I love the panoramic ceiling. headlights and wipers are automatic and manual. armrests, functional back seats, service tables, cooled deep torpedoes are useful. I could not look at the indicator and trip computer in detail. I will examine them too. The teacher friends at the school liked it very much.
& nbsp;
full pleasure tool for those who are not looking for sportiness ...
08.05.2020 16:23 # 8
I am using the same model as the 2003 model of your vehicle. Mine is the pack version. Another feature that you have not mentioned and you will understand its beauty in the future is that the rear seats can come out one by one. Moreover, these seats can be placed on the trunk. I saw it here, the back seats were completely removed and the two were put in the trunk. In this case, it becomes a super play venue for children. & Nbsp;
08.05.2020 16:23 # 9
albayman
By the way, I can't get used to the fuel gauge. The fuel seemed to be constantly decreasing because it got the data from the wheel movement. When I bought it, there was a quarter of a gas tank in Friday. I bought a 30-liter gasoline. & Nbsp; lpg vehicle should last more than 2 weeks (I used corsa 98, I know from there) right? mornings pass to lpg quickly. & nbsp; there is no gas at the moment. How do those who understand the LPG vehicle?
08.05.2020 16:23 # 10
albayman
[QUOTE = koliva] I am using the same model as your vehicle in 2003 model. Mine is the pack version. Another feature that you have not mentioned and you will understand its beauty in the future is that the rear seats can come out one by one. Moreover, these seats can be placed on the trunk. I saw it here, the back seats were completely removed and the two were put in the trunk. In this case, it becomes a super play venue for children. & Nbsp; [/ QUOTE]
previous owner told them all I don't have any trouble with the seats for now, thank you.
I can't do what you say right now because there is an LPG tank in the back. I will think of a solution in the future, no children yet :))) no problem :))))))
08.05.2020 16:23 # 11
tolga35
Good luck bro, I think straight gear, put the first gear and pull the handbrake to let you know that the clutch is missing. If the vehicle stops, the clutch is intact.
08.05.2020 16:23 # 12
yavuz25
[QUOTE = tolga35] good luck bro, I think the straight gear, if the car stops, the clutch is intact. [/ QUOTE]
I can't say anything to the right path, but it is dangerous because it will be an act that corrodes the clutch. In the same way when you are on the upside, when you change the gear to 4 and turn the speed to 3000, if the speed is 120, there is no problem, but less speed & nbsp; If it is missing then the pad is missing. It is a little long but ... "Wink"
yavuz25 2011-11-22 22:36:01
08.05.2020 16:23 # 13
albayman
good morning, thank you guys ...
the speed-speed-gear ratios of the vehicle do not change, it does not matter whether it is uphill or uphill, it is always the same. the clutch is not exhausted, but I think it's pretty worn. it seemed to me kidnapping. I don't feel the kidnapping when I throw it from 1 to 2. It accelerates very well, it sticks to the seat.
There is an uphill support, I understood it in the car. in order to avoid stopping on flat ground, it is necessary to step on the throttle a little because the car is heavy. and especially in 1st gear, the car has its own character. But as I climb uphill, even if I touch the throttle as soon as the clutch engages, it is a little more than 2000 rpm.
& nbsp;
and when I had the problem of relay-take-off in my previous vehicle (1998 corsa gls), it was connected to the machine and understood & nbsp; master, engine temperature sensor and idle sensors and sockets were beautifully cleaned, free from corrosion. there was no problem. When I connect it to the machine, I will specifically ask, have it cleaned.
& nbsp;
and would you share with me how you understand this gas gauge? :)
08.05.2020 16:23 # 14
yavuz25
Then you can use your car in peace of mind. "Wink" What about the gas gauge you are asking when I don't fully understand. "Smile"
08.05.2020 16:23 # 15
albayman
My car is lpg, so it does not use gasoline even for 5 -10 minutes until it only switches to lpg. but as you go, the gasoline needle drops. Even now the petrol needle is at zero :) but I'm sure there is gasoline in the car. There was a quarter tank when I bought it, I added 30 TL more. I came from Izmir to Aydin, Nazilli, Mugla. Now I make 40 km every day. I bought LPG again, but I didn't buy gasoline. the hand is ZERO you know :) but i'm sure there is gasoline in the tank.
& nbsp;
, these pejos were getting data from the wheel and not from the tank. In addition, he did not recognize the insulation placed less than 7 liters and reflect it on the display.
& nbsp;
*** I wonder how 307 users with 1 lpg understand the amount of gasoline in the tank? and he wears a key, but I'm not a fan of spoiling the originality ... I will change tires with tie rods ...
& nbsp;
*** 2 & nbsp; my car is 2005 model at 42000 km. ... & nbsp; do you think timing etc will change? Or should I wait for 60000km and replace it?
& nbsp;
& nbsp;
will also be connected to the machine this weekend.
& nbsp;
*** When I go to 3 industries, what should I check and do? Users know the tricks better.
08.05.2020 16:23 # 16
yavuz25
1-) The gas gauge may be showing correctly but when you switch to LPG, the valve that cuts off the gasoline may be missing. This will burn the gas as the distance goes, so you will burn double fuel. Now, some friends will say, don't you have a misfire? If there is not an excessive amount, there will not be a misfire. Soup becomes salt;)
2-) km is less than 6 years. ) If the front layout is checked, it would be better if you look at the parts that should change periodically in the engine. "Wink"
08.05.2020 16:23 # 17
albayman
thank you to all the friends who helped.
Let's look at it this weekend, then let's take it back with you. if it passes, i will have it in the future. & nbsp; now lpg tank is in the trunk and 50lt is covered with huge space :) I have no problem for now but I will act according to the answer from the tweed in the future ...
& nbsp;
I slowly write my comments as I drive. I am following the forum from time to time, very nice sharing place :)
& nbsp;
hope to see you.
08.05.2020 16:23 # 18
albayman
CD CHANGER ALTERNATIVE RECOMMENDATION
I opened a topic in the title of my music site, but let me write it here,
I thought of the cd changerin, it was like this:
& nbsp;
a usb-sd adapter called anycarlink is sold on the market (I don't know if it fits our car). How can I remove the cd changeri completely while it is canceled, put the same size black, open box in front of it, install the usb-sd adapter on one side of this box and use it as multimedia?
& nbsp;
usb-sd adapter and cd changer size box recommendation for my vehicle?
& nbsp;
thanks ...
08.05.2020 16:23 # 19
yavuz25
I recommend not interfering with the original. "Wink"
08.05.2020 16:23 # 20
albayman
Something called xcarlink and user reviews seem positive. 6 folders such as cd01 cd02 cd 03 ........ and maximum of 99 mp3 can be thrown into the memory. It connects to the cd changer input (8pin miş) and recognizes it as cd changer. We can change the mp3 like a folder and track, just like replacing cd from the steering arm.
yes I always say original but this cd changer is not like to be shot ...
