I did not understand what happened (with pictures) "solved"
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 18:17 # 1
Bugra
friends just started my car. I turned the steering wheel a little, a clat was broken, but the car continued to operate normally. I did not try to go into gear with fear, only the steering wheel I observed was stiff, I turned the engine on, and I saw these. he was on the strap. I did not understand what happened. I'm waiting for your help Mr. Grant 2014-02-15 10:45:50
08.05.2020 18:17 # 2
Bugra
I guess it was a grank pulley. the vehicle was walking but it was eaten from the battery. The steering was stiff in him, as he threw the strap.
08.05.2020 18:17 # 3
terzuu
Don't start, the belt pulley has been bought, and I hope the engine hasn't done much damage. tool. Get well soon.
08.05.2020 18:17 # 4
terzuu
zeroing on the walking part. It is a break from metal fatigue.
08.05.2020 18:17 # 5
[QUOTE = terzuu] don't start the belt pulley has gone, so it didn't hurt the engine too much. tool. get well soon. [/ QUOTE]
Okay, it's okay to run it, but it's not a timing that you can damage the engine and get it out.
the crank helps just turn the charger, air conditioning compressor and steering pump.
I think you're messing up.
08.05.2020 18:17 # 6
Bugra
The inner part of the broken wheel is made of cavity. When I looked at the parts list, its name is grank pulley. as if the visible damage was just that piece
08.05.2020 18:17 # 7
[QUOTE = Buğra] the inner part of the broken wheel is black. When I looked at the parts list, its name is grank pulley. as if the visible damage was just that piece [/ QUOTE]
In diesel vehicles, the rubber of the crank pulley is larger.
For example, in my 207 only in the form of a gasket where it is attached to the crankshaft.
But friend, you will damage the motor or something, and it must break the trig in order to damage the motor.
get past it.
It happened where you stopped from Allah. As I traveled at a speed of 80 km, he jumped and overtook the car.
you think the rest ...
08.05.2020 18:17 # 8
Burak
I agree with brother, Maverick, get well soon.
08.05.2020 18:17 # 9
Bugra
understood, thank you guys. tomorrow I am slowly taking the path of industry
08.05.2020 18:17 # 10
Bugra
I guess this is the piece I will take. However, do I need to buy anything else? the bidet is the original piece but it doesn't look like the middle one is small
08.05.2020 18:17 # 11
[QUOTE = Buğra]
It would be better if you give the chassis number and get it.
I have painful experience in this regard.
I lived in civic. 2. once broke the crank stud. That is, the bolt of the crank pulley.
Turns out, the pulley is old because it is old. So the wheel bolts are balanced and the pulley is broken.
The wheel bolt is as important as the pulley. I requested the civic wheel bolt from the authorized service. and that bolt needs to be tightened with a torque of 35 nm. was writing in the driver's manual of the bolt.
I think you want your studs too.
08.05.2020 18:17 # 12
I think it's okay .. the roll is scattered inside. enough to renew the parts and belts in the picture.
08.05.2020 18:17 # 13
tongucuk
I don't know if it can be done in the place where the car is at the beginning of the car, even if it is past, even if it is the master of the car, but I wish it would be possible to solve the problem without moving it.
08.05.2020 18:17 # 14
ahmet_bjk
I think [QUOTE = Buğra] was the grank pulley. the vehicle was walking but it was eaten from the battery. The steering was stiff in him when he threw the belt. [/ QUOTE]
How does it eat from the battery?
08.05.2020 18:17 # 15
Bugra
[QUOTE = ahmet_bjk]
I guess I didn't fully understand it because it was thrown on the belt that rotated the charger
08.05.2020 18:17 # 16
barishrocker
get well, bless Allah. good that you weren't mobile ..
08.05.2020 18:17 # 17
Bugra
[QUOTE = barishrocker] get well, bless God. good that you weren't mobile ..
Well, peace is the only consolation when it is in front of the house. Since I was in the crankcase at the bottom, when that wheel fell, I heard a noise, I said aha, we finally broke the car Cry
08.05.2020 18:17 # 18
barishrocker
man is afraid. There was a voice behind me at the meeting. We even guessed that the back amortization was gone. Turns out, the thermos and the fire tube were hitting each other :) The first time, people are very afraid, but we have to get used to such things ...
08.05.2020 18:17 # 19
furkanyakar
[QUOTE = ahmet_bjk]
Since the [/ QUOTE] charging dimer has no belt, the charging dynamo will not work and will not generate electricity from the vehicle movement. Therefore, using the electric source battery, it will discharge the energy of the electronic devices.
If you drive it using the vehicle, the headlight signal, park radio, etc. Turn off everything without going to operate anything electronically so that you do not overeat the battery.
08.05.2020 18:17 # 20
Bugra
[QUOTE = is furkanyak] [QUOTE = ahmet_bjk]
Exactly, my friend, I plan to die tomorrow morning. I wouldn't even run the wipers here even though it was rainy here.
Page : / 2
