I could not disassemble it :( (Y.airbag)
08.05.2020 16:06 # 1
deamod
Guys, no one is shedding any of them, I can only remove the bolt from the nerves, I could not unscrew the nut that came in front of me. There is no field. I beg you to explain it or I'm going crazy ...
08.05.2020 16:06 # 2
peugeotefe
I think if you are trying to remove the right airbag, then you will remove the torpedo cover and remove it with its inner eye.Then you have 2 pieces of 20 tors bolts and 4 pieces of 8 nuts.
08.05.2020 16:06 # 3
deamod
everything has a first thing, now it is left to remove the torpedo cover: D cover, remove the 20 tors bolts, remove 4 pieces of 8 nuts, sand the torn place, fill the inside with yellow foam, close the tears, fill it with silicone and draw 3m coating on it: D yes I will do all of these :) :) :)
08.05.2020 16:06 # 4
deamod
Thank you. By the way, what is the place you call this cover?
deamod 2011-09-08 20:08:51
08.05.2020 16:06 # 5
Look at me, I think it will explode in your face, paralysis stays, you get locked, don't show it;)
08.05.2020 16:06 # 6
deamod
No, my brother, it will not explode. Can I tell you about an empty airbag without airbag?)
08.05.2020 16:06 # 7
[QUOTE = deamod] No, no, my brother will not explode, couldn't you explain the empty airbag without airbag:) so it's okay [/ QUOTE]
Are you trying to repair the explosive state ???
08.05.2020 16:06 # 8
I did not understand the situation, can someone explain immediately Confused Cem brother understand me
08.05.2020 16:06 # 9
calpsize
[QUOTE = berkekk] Look at me, I think it will explode in your face and it will be paralyzed.
You have to be careful :) Sırıtma
08.05.2020 16:06 # 10
metin
I'm very confused too.
08.05.2020 16:06 # 11
deamod
Friends, confusingly, I am trying to close my passenger airbag, which has exploded, at a low cost.
The transactions will be in the following order;
1. airbag removal
2. Sanding the ripped coating
3. Cutting the air bag and filling it in empty spaces with foam (such as the yellow squeezer dries and remains intact until dry, to minimize rupture from the seat)
4.Filling silicone in the gaps in the sanded areas (in order not to look bad when we pull the coating)
5. 3m carbon coating or foil but I think the carbon coating will look more beautiful (I'll cover the chest afterwards)
Maybe my narration may be wrong, but if I find the opportunity in the future, I will do it and illustrate it and share it under a separate subject.
08.05.2020 16:06 # 12
I think it won't work, I think you go to a service Ağlama
08.05.2020 16:06 # 13
[QUOTE = deamod] Guys, I'm not going to get confused. I'm trying to close my exploded passenger airbag with little cost.
1. airbag removal
So I got it right Sırıtma
Whatever you do, it is much more beautiful than it used to be. Get rid of the bad view of the broken airbag Göz Kırpma
Or you can cover your skin to a reporter with no hiccup. Maybe it is more beautiful and easier but it can be more costly ...
08.05.2020 16:06 # 14
deamod
I want to fill the bidet more than its cost, I know that the car will blow the airbag to the 3 doors and those who do not know the seat, so if I cover the leather, it will be certain again due to the impact and I will be torn again. Whatever happens, I think it can't be as ugly as this ugliness, no matter what
