I cleared the gas butterfly throat.
08.05.2020 16:20 # 1
Exit the air filter & nbsp; up to 15 cm & nbsp; I removed the spral tube in length. On the one hand, I gave gas (I pulled it up to the redline) and squeezed the lining spray into my throat. I wonder? Will it recover over time? laedri 2011-11-05 14:28:55
08.05.2020 16:20 # 2
ose
The cleanliness was nice and there was no need for a redline U will improve.
08.05.2020 16:20 # 3
sedataksu
It would be better if you disassemble and clean the vehicle instead of working.
08.05.2020 16:20 # 4
I Love My Pug
Goodbye use, brother, where are those sprays sold, I wonder if there is any harm, right? I want to clean my engine.
08.05.2020 16:20 # 5
sedataksu
[QUOTE = I Love My Pug] goodbye, brother, where are those sprays sold, I wonder if there is any harm? / div>
Würth engine cleaning spray is not bad at its price.
08.05.2020 16:20 # 6
I Love My Pug
Brother is not going to do any harm whatsoever, würth is better when it comes to the cables or something, I guess in quality?
08.05.2020 16:20 # 7
Ucyuzalti
Friends & nbsp; I did it today, I first saw that gas reactions improved, as if performance increased. Likewise, I cleaned the spark plugs from the air filter pipe. After that, I clean the throttle once a year & nbsp;
08.05.2020 16:20 # 8
calibration may be required.
I have opened and discussed this issue before.
your fuel consumption may increase.
08.05.2020 16:20 # 9
tayfundoner
tomorrow my first job will be throttle air filter pipes cartel cleaning :)
08.05.2020 16:20 # 10
SZKR
After this process, the vehicle must be connected to the planet and calibrated.
08.05.2020 16:20 # 11
pad spray is sold in accessories and tire makers in most places between 5 and 10 TL I bought it to clean the oil residue on the sides of the engine.
08.05.2020 16:20 # 12
Ucyuzalti
I wonder if this 306 is valid?
08.05.2020 16:20 # 13
VEDATDINC
Put the throttle between your hand and open it, squeeze something between the hand and make sure that there is a gap.
08.05.2020 16:20 # 14
I made about 200 km after the procedure.
Idling is back, it seems as if there is no need for calibration. .
08.05.2020 16:20 # 15
hamham
friends, this is exactly where the throttle and spark plugs you said and where can i clean it myself
08.05.2020 16:20 # 16
mon
friends at least 10 people did not have 1 photo of this operation.
please help the friends who do not know how to take photos of our transactions.
08.05.2020 16:20 # 17
tolga35
friends, do not try while the vehicle is running, the sprays spray should be done when it is a flammable gas while the engine is not working directly when the vehicle is not working.
08.05.2020 16:20 # 18
Ucyuzalti
Throttle valve
08.05.2020 16:20 # 19
mehmetaydinpug
Before the friends disassemble the throat butterfly, be careful about the risk of opening and licking, since all the keys are keyed, then you will think about how to remove it :)
08.05.2020 16:20 # 20
Ucyuzalti
If the lathe is forced by screw, it will be licking 2 + 2 = 4 "Smile" & nbsp; It is better to do it with allen because the allen screw is always healthier and tightened better than the regular screw.
ÜÇyüzaltı 2011-11-23 23:30:14 < / edited>
Page : / 2
