I changed the remote's battery, the doors won't open
08.05.2020 18:27 # 1
alperuzuntas
Hello friends,
I joined you from Balıkesir, it takes about 1 week.
I got the 2006 model makeup case 307 ..
I have recently read a text on the screen, which means the control battery is running out.
I bought the new battery, changed it .. but now I can't open the doors from the remote.
I searched for a few places in the forum, with the key inserted and 1 click away, press the on or off key
I haven't tried it either.
is there anybody who can help aceba?
alperuzuntas 2014-04-13 11:06:24
08.05.2020 18:27 # 2
C@GL@R
some cars have a setting I don't know how the pejoda mesala skoda also when turning the ignition, you were holding down one of the on / off buttons after the battery change, the pejoda might be like that. check the simplest, insert the battery correctly, the battery is on, if there is light on the remote control, etc ... then look what i said
08.05.2020 18:27 # 3
alperuzuntas
the battery is inserted correctly, there is no light on the controller.
I tried with the old battery as well, if the battery I just bought was exhausted.
friends, I think I did it :)
1 click forward with key inserted, (engine will not start, only indicator lights will come on)
While in this position, first press the power button for 10 seconds and then remove the key.
Do the same thing for 10 seconds by holding the unlock button and remove the key.
At first it seemed like it did not work, I started the car, I drove a little, when I parked, I touched the discretionary control, and the doors closed.
I hope it will help if anything else happens.
( Friends who have received the plip key battery spent warning will soon run out of your remote and will be able to analyze it as I wrote above without falling into my situation.)
alperuzuntas 2014-04-13 13:44:52
08.05.2020 18:27 # 4
ahmet_bjk
Thank you for the information. Some of our friends find solutions to their problems somehow, but they do not go back and share them here, it is nice to share the solution as someone who has found the same problem that someone else may have experienced.
08.05.2020 18:27 # 5
ucanturk
thanks for sharing.
but my 2002 model xt didn't work either.
I tried in one click, I tried in two clicks, I made up, but it didn't happen.
there is no problem in the central lock. As if I locked it from the button inside, there is no problem, the light on the button lights up. I haven't found the problem yet ??
08.05.2020 18:27 # 6
suppor
I realized that my battery did not open remotely because the doors did not open, then it did not open at any time, I went from the door at the door, went to the doors, said to the electrician, master gave me a battery, and I gave the same tactical 4 tl 1 battery Now even 50 meters did not require a tuning or something and the vehicle 206 meanwhile
08.05.2020 18:27 # 7
ahmed206
The synchronization procedures for 2002 and 2006 are the same:
Turn the ignition but do not start
Hold down the lock key for 10 seconds
Turn off the ignition. Wait 5 seconds.
ahmed206 2014-07-09 13:20:33
08.05.2020 18:27 # 8
ucanturk
Mine doesn't work anyway.
What could be the reason?
08.05.2020 18:27 # 9
ahmed206
The battery of the controller is not installed correctly
