I can't solve my cruise control
08.05.2020 21:12 # 1
Leventusta
Dear friends, the speed stabilization of my lion does not come into play, the limitation is working. Control lever clutch sensor brake sensor.
My personal opinion may not perceive that the vehicle is in 4th and 5th gear, but who knows how and where the vehicle is perceiving 4 or 5th gear and who can give advice or help in this regard.
08.05.2020 21:12 # 2
iso0625
So, does the line on the screen start flashing when commissioning? Also, if you try to activate cruise control like 20-30 while driving at low speeds, does the road computer display a warning like "speed too low cruise control cannot be activated" or similar? iso0625 2019-03-31 01:22:09
08.05.2020 21:12 # 3
Leventusta
Yes, the line appears on the line, the current km says yide, it starts to jump when it increases or decreases, I can not apply the low speed event.
08.05.2020 21:12 # 4
iso0625
I also had such a malfunction, I solved it in this way.
08.05.2020 21:12 # 5
Leventusta
we checked the encodings, we disabled the limitation, but we never turned off the fixing, let me try it on tomorrow. Cry
08.05.2020 21:12 # 6
iso0625
Yes, an annoying situation, if there is no problem with the consumers, I did not have trial and error. If you write whether it works or not, we will be informed.
08.05.2020 21:12 # 7
Leventusta
If it comes into effect, I will definitely try tomorrow
08.05.2020 21:12 # 8
My teacher determines that work according to speed and speed. As far as I remember. Did you change the arm and experiment? Or did you just disassemble and check it.
08.05.2020 21:12 # 9
Leventusta
teacher, I tried a full three arm, one new zero, the other two, I bought a working vehicle, I even attached my parts to that vehicle, no problem, overlaps my vehicle's parts
08.05.2020 21:12 # 10
Leventusta
today I turned off the coding from both the motor brain and bsi and turned it on again. Cry
08.05.2020 21:12 # 11
You have done many of the procedures to be done, then my teacher has engine ecu and bsi control.
08.05.2020 21:12 # 12
maximusti
I opened it in a 207 that I couldn't open with diagbox before, by trying it with peugeot planet,
Have you tried it with peugeot planet?
