I burned 100 / 4.66 lt outside the city
08.05.2020 17:02 # 1
goktug
Hi friends. I burned 35 liters at a distance of 750 km from Kayseri to Istanbul two days ago. 4.66 lt per 100 km. my speed is 130-140 t most of the time. I haven't been measuring fuel for a long time. how do you think the rate? I did not replace the diesel filter in maintenance. If I change it too, can I drop the fuel a little more?
08.05.2020 17:02 # 2
istanbullu_3886
I came to Istanbul with my car in Kayseri, which is the sign of fuel.
08.05.2020 17:02 # 3
nupel307
4.66 liters of fuel is not possible at a speed of 130-140 km .. not a mistake & nbsp;?
08.05.2020 17:02 # 4
_pathfinder_
Yes, I had an average of 5,5-6 lt at 130-140km speed when I had the 2006 307 1.6 hr. So if you change the diesel filter as the 206 hds, you have coordinated a very successful rpm throttle shift coordination. & Nbsp; & nbsp;
08.05.2020 17:02 # 5
tellotello
[QUOTE = _pathfinder_] Yes, I was burning an average of 5.5-6 liters at a speed of 130-140km when I had the 2006 307 1.6 speed, so if you change the diesel filter as a 206 hp, you have coordinated a very successful turnover of gas gear shift & nbsp; "Thumbs & nbsp; [/ QUOTE]
+1 < / div>
Also, I feel a bit difficult with 130-140s but & nbsp; "Smile" & nbsp; I guess the tool was not installed.
08.05.2020 17:02 # 6
drakman
Super result, I'm not surprised.
08.05.2020 17:02 # 7
goktug
The vehicle's luggage and rear seats were full. the items were heavy. I was the only passenger. I remember shifting the gear to 5 after entering the bus in Ankara. It is almost as if there was no shifting work until Istanbul.
08.05.2020 17:02 # 8
goktug
[QUOTE = nupel307] 4.66 liters of fuel with a speed of 130-140 km is not possible ... no mistake & nbsp;? [/ QUOTE]
took 35 liters when I refilled the tank at the end of the trip. This is the case if my math is wrong ...
08.05.2020 17:02 # 9
cerci07
normal long road average down to about 206 to 4.7L 100km
08.05.2020 17:02 # 10
nupel307
I used 307 1.6 hdi 110 horsepower before .. now I use 308 1.6 hdi 90 horsepower.
08.05.2020 17:02 # 11
goktug
Isn't it more logical to consider the value of the trip computer, not my teacher, if you last took the official measurement. because the road computer provides a prediction but it does not give the ratio of the total road at the end of the road to the fuel.
08.05.2020 17:02 # 12
Sufibey
& Nbsp; & nbsp; Your fuel consumption is fine according to the conditions and usage conditions you say. If particles are not accumulated inside your diesel filter, it will not affect fuel consumption. But if it's time and you haven't changed, I think it will have an impact on fuel consumption.
