I broke a pipe I didn't know its name |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 16:30 | # 1 |
| 08.05.2020 16:30 | # 2 |
What is going through, my brother? Is there a cable or something?
| 08.05.2020 16:30 | # 3 |
the inside of the walla brother was slightly oily but when it broke it didn't flow anymore there is no cable inside, there is a big thick pipe going to the air filter on the other end of this pipe or it goes into it I could not take a picture because it is the night the big pipe does not appear from my vehicle
| 08.05.2020 16:30 | # 4 |
Isn't it an oil vapor hose? Varies & nbsp; you will find that hose in the pieces. If they closed well, but the hot silicone it melts there or the hot oil melts the steam, I think change it. |
| 08.05.2020 16:30 | # 5 |
I asked my teacher, the service said 105 TL, so what is necessary, is it so empty :)
| 08.05.2020 16:30 | # 6 |
[QUOTE] ] I don't need if silicon is caught. There is no pressure or vital thing in it. Maybe it is oil vapor hose as my brother says. Better go over that silicon one more time.
| 08.05.2020 16:30 | # 7 |
It doesn't matter if the oil is a steam hose. The silicon is ok. |
| 08.05.2020 16:30 | # 8 |
They siliconized in the service, my master said these things are connected to the manifold, he did not say the name of the hose :) I wrapped a tape around it, I say it will not be a problem.
| 08.05.2020 16:30 | # 9 |
| 08.05.2020 16:30 | # 10 |
Yes, it is the exact oil vapor hose, but it is not silicon, but it is necessary to insert another hose out of it and fix it with a clip. & Nbsp; clip. > edited>
| 08.05.2020 16:30 | # 11 |
[QUOTE = 06EZGÜR06] Isn't it an oil steam hose? Varies & nbsp; you will find that hose in the pieces. If they closed well, but the hot silicone it melts there or the hot oil dissolves the steam, I think change it. [/ QUOTE] I think that black silicone will not melt, my brother.
| 08.05.2020 16:30 | # 12 |
brother, what science pipe is in my hand :)
| 08.05.2020 16:30 | # 13 |
Is that hose original?
| 08.05.2020 16:30 | # 14 |
I think it's original on you
| 08.05.2020 16:30 | # 15 |
I think it is original on [QUOTE = htasay] [/ QUOTE] Because I usually ask for oil steam hoses are rubber soft rubber hoses rather than hard plastic. |
| 08.05.2020 16:30 | # 16 |
[QUOTE = htasay] brother what science the pipe is in my hand :) i did not climb it but i said it is halfway the car is gone :)) [/ QUOTE] |
| 08.05.2020 16:30 | # 17 |
bro, it broke from my face, I was going to prevent the radiator water that our brothers shared with it, from leaking in.
| 08.05.2020 16:30 | # 18 |
Brother your engine part is very confused or as if they have been forced to tighten the engine there |
| 08.05.2020 16:30 | # 19 |
this is not my engine brother bro i found a picture like mine :) but the pipe is the same pipe no problem :)
| 08.05.2020 16:30 | # 20 |
[QUOTE = htasay] this is not my engine brother bro I found a picture similar to mine :) but the pipe is not the same pipe problem:) [/ QUOTE] |
