I bought the new Peugeut 206 Feline 1.4 8v, please help
08.05.2020 16:31 # 1
206feline
Hello friends 1 week ago Peugeut 206 Feline 1.4 8V 55 HB Gasoline & nbsp; I joined you by buying manual gear. I was very excited because it was my first car. Also, the person I bought the linings said that he had just changed his oil and filters.
& nbsp;
& nbsp; When I first bought it, I filled the tank and after I traveled for 153 km, I reloaded 53 TL more gasoline. The liter of gasoline was 4.25 liters, it burned 12.5 LT and 0.35 TL on the long road. Do you say much of your ideas? what do I need to do? >
& nbsp;
I want to have LPG on which brand I want to install. How much will my fuel consumption decrease?
& nbsp;
DIV> & nbsp;
08.05.2020 16:31 # 2
yavuz25
Check clutch lining, check brake pads, tighten discs. Wink "title =" Wink "/>
08.05.2020 16:31 # 3
206feline
Thank you ya 25 25
& nbsp;
I think I have read somewhere on the internet.
& nbsp;
Will it drop if you install a lpg directly in the vehicle that is not serviced? Or can these maintenance be done after the gas is installed? Well, when I bought the new vehicle, I got into a lot of debt.
08.05.2020 16:31 # 4
KenBlockJR
research burns excessively. do you make a mistake?
08.05.2020 16:31 # 5
yavuz25
[QUOTE = 206feline] Thank you yavuz 25
& nbsp;
I think I have read somewhere on the internet. ?
& nbsp;. Or can these maintenance be done after the gas is installed? Well, when I bought the vehicle, I got into a lot of debt.
& nbsp;
Which is the most economical and right solution for you? ]
my brother is better if you measure fuel consumption correctly in calm use. "Wink"
08.05.2020 16:31 # 6
kudret_yildirim
12,5 lt on the long road. you? No 6 cylinders 206 :))
08.05.2020 16:31 # 7
C@GL@R
Finish the best measuring gasoline, take it completely afterwards. Put 50 petrol in a 50-liter gas tank in a 5-liter water bottle.
08.05.2020 16:31 # 8
fTh206
I think it burns a lot in mine, I am burning 35 krş km, but I think mine is normal
08.05.2020 16:31 # 9
anilkaptan
I have feline 75 horsep. A problem similar to the same problem happened in my vehicle. We did not take any service but I took one of my friends to take ideas that could be thought of without tampering. continued, the electric cable that came to the spark plug was making slight contact, after replacing the fault, it replaced the previous coil, the problem is over now. 19.kr.
