I bought a peugeot 206 1.4 petrol. your advice?
08.05.2020 18:20 # 1
dalgakiran
hi friends automatic gear 2004 mod. I bought the vehicle at 100,000 km
my first automatic gearbox
what is your advice
breakwater 2014-02-25 21:49:26
08.05.2020 18:20 # 2
Turgay_66
good luck, auto users will help you :)
08.05.2020 18:20 # 3
SDYMZ
Enjoy it
08.05.2020 18:20 # 4
Moda0797
good luck without trouble
08.05.2020 18:20 # 5
kivanc
[QUOTE = breakwater] hello guys automatic gear 2004 mod. I bought the vehicle at 100,000 km
what is your advice
Enjoy my advice :)
08.05.2020 18:20 # 6
samet206
Good luck, after your car is regularly maintained, there is no situation to be over 206 recommended, just be kind to the vehicle, enjoy yourself ...
08.05.2020 18:20 # 7
tongucuk
Use it on a good day without an accident. Thumbs Up
08.05.2020 18:20 # 8
ahmed206
It is enough not to interrupt their periodic maintenance :)
Best wishes
08.05.2020 18:20 # 9
Serkan
Good luck, make sure that the vehicle stops completely when passing from r to d or d to r, take the car to the parking place, apply the parking brake and then take it to p.
08.05.2020 18:20 # 10
Barut
[QUOTE = Serkan] Good luck, make sure that the vehicle stops completely when passing from r to d or from d to r, when parking the vehicle, first take the car to n, apply the hand brake, then take it to p. [/ QUOTE ] As someone who has used 206 automatic, I agree with Serkan evening dresses.
08.05.2020 18:20 # 11
rizeli_53
good luck without any trouble, i hope
08.05.2020 18:20 # 12
oguzhan29
We wish you good luck.
08.05.2020 18:20 # 13
aremtu
My advice is, wear LPG.
08.05.2020 18:20 # 14
tetik-soner
good luck .... yes, just like the serkan says, when parking, first take the N position, pull the HAND BRAKE , then take your foot from the BRAKE and put it into the P position ...
08.05.2020 18:20 # 15
Mesut48
[QUOTE = trigger] good luck .... yes, just like the serkan says, when parking, first take the N position, pull the HAND BRAKE , then take your foot from the BRAKE and put it into the P position ... [/ QUOTE]
I wondered why Smile
08.05.2020 18:20 # 16
Serkan
[QUOTE = Mesut48] [QUOTE = trigger] good luck .... yes, just like serkan says, when parking, first take N hand , pull HAND BRAKE , then take your foot from BRAKE and put it into P ... [/ QUOTE]
If the handbrake is applied first to P and the vehicle's load is loaded into the gearbox, but if the handbrake is applied to P first, the load of the vehicle is applied to the handbrake. In addition, the gear lever movement is very comfortable for the first start.
08.05.2020 18:20 # 17
tetik-soner
[QUOTE = Serkan] [QUOTE = Mesut48] [QUOTE = trigger] good luck .... yes, just like serkan put it in position N , pull the hand brake , then take your foot from the BRAKE and put it into P position ... [/ QUOTE ]
If the handbrake is applied first to P and the vehicle's load is loaded into the gearbox, but if the handbrake is applied to P first, the load of the vehicle is applied to the handbrake. In addition, the gear lever movement will be very comfortable for the first start. [/ QUOTE]
exactly Thumbs Up
08.05.2020 18:20 # 18
dalgakiran
Thank you guys for your valuable answers.
There are 5 pieces of paint on the vehicle. But the paints are half half. We said it would be that. 100.000 km. It is very clean.
When I brought it to the master, the engine coolant decreased a little. Accordingly, the cylinder head gasket will be replaced. etc. vs 500 tl charge. we dropped it off the price. I was thinking about having a tube of muanesi made 4 months ago, but I said I'm waiting a little bit because muane is new. or if I do not get it running, I wonder what happens to the license .. I am unaware of using it as such, but we bought a vehicle without debt, getting into debt and having a tube + operating it is heavy for me. e comfortable vehicle automatic gasoline too, I bought this on purpose but I don't know how much it will burn :( I will follow your advice exactly.
I expect advice from you, promising that I will fully comply.
We signed the vehicle in this way for 15700 TL. There will be a cost of 500 TL.
Best regards
08.05.2020 18:20 # 19
tetik-soner
you bought good price use goodbye ... use a little gasoline you started pushing the budget ouzman go to the tube ... you have the S button, you can use the car as 1 and then take it to S, you can use it like a manual ... throws ... if you root the gas while driving in position D LOL You will see 100 in a few seconds.
08.05.2020 18:20 # 20
dalgakiran
thanks for the information, but i dont understand this s event manual event :(
Page : / 2
