I bought 307
08.05.2020 18:08 # 1
MehmetMehmet
I just joined your friends, as of last week, I bought 2003 model 307 technoplus. I bought it as second hand from my teacher friend, so he bought it from scratch and he was 10 years constantly, and now I bought it. He did not wear any lpg, all maintenance was done in the authorized service, 140000 km In the last 130000, the press brake, the timing changed, 4 tires michelin got zero before 2000 km.I had no blow paint in the car.When I received it, I had 140000 maintenance, though I did not take it to the authorized service because I made it there because my friend worked in the ford authorized service. Everything from A to Z that you will understand, undercarriages, spark plugs, thermostats etc. were checked and necessary changes and maintenance were done. I would be glad if you help me if there are some questions I will ask here:
1-I bought the vehicle for 16000 TL, maintenance costs + transfer + insurance + insurance all cost me 17500 TL, is it normal or expensive at this price?
I will travel 2-days 10 km and maximum 300 km per month (in the city), that is, I will not go out of the city until the summer vacation, in this case I should have lpg, if yes, which brand and model should I have?
3-Would this model be a speed stabilizer, how much would it cost?
4-While the car is running idle, there is a tremor in my feet, even though it is very light, when I ask the friend, he said that the calibration should be done because he cleans the throat butterfly, he has it connected to the computer in the industry, but how much does it cost while the electronic parts of the car occur?
5-I will give the car a complete interior-exterior cleaning for the week, do I wash the engine part and have it protected?
6-Although my old car was a hawk, it would go away when I touched the gas with his toes, but this car does not go away when he touches the gas, but I have to press the gas with my feet, is this normal?
7-Do you have anything to think of and do I need to do in use-maintenance etc.?
Thank you very much to everyone in advance ...
08.05.2020 18:08 # 2
MehmetMehmet
8-everything works only cd and cd changer part does not work, had it done many times before but did not keep order, where can i get it, is it a chronic problem?
08.05.2020 18:08 # 3
MehmetMehmet
do not look at the defect that comes to my mind later
Since the screen with the 9-way computer is orange colored, it is not very clear especially during the day, but the night is good, but it does not appear much from daytime light, does not the screen have a white LED?
08.05.2020 18:08 # 4
Serkan
First of all, I would like to welcome your vehicle and try to answer as much as I can.
1-The price is fine, trying to sell 206 at these prices is generally
2-I think there is no need for the advantage of LPG fell to 30%, unfortunately there are problems
3- If there is 4 wires in the socket coming to the brake sender and the brake pedal is electronic (pedal electronics according to your 6th question) Our cost fixing arm sponsor is 110 TL in the campaign at peugeot market and an average of 50 TL in activation .
4-Throat butterfly adaptation is not more than 20 lira.
5-Do not touch the motor, I think you can do it yourself by wiping the motor cleaning with engine cleaning sprays yourself.
6-The brake pedal is normal because it is electronic, so when I get on my father's broadway, he suddenly gets plowed.
7 .....
Do not deal with the repair of the 8-CD player, it does not keep order, either change the tape or take it from the device called audio system, you can see the device in the link below.
9- 307 screens have more problems with fading than the light, you cannot solve it by changing the light color.
Serkan 2013-12-10 02:34:01
08.05.2020 18:08 # 5
MehmetMehmet
Serkan Bey, thank you very much ...
08.05.2020 18:08 # 6
MehmetMehmet
friends, this is the 4th question, i.e. while the car is running idle, there is a tremor in my legs even if it is very mild, this is the calibration because the throat butterfly is cleaned as the friend says?
I will also have another important question, I am starting the car the other day, but it doesn't work anyway. I asked the friend, he changed something in the fuel pump, we bought a Bosch brand from the industry (75 TL).
According to the friend, the fuel pump had to be replaced, but it was also expensive. Should I replace my fuel pump? Or is the problem solved in a different way? If the pump is definitely going to change, how do you suggest going out or the original or supplier industry?
I'm sorry I am a newbie of the car.
08.05.2020 18:08 # 7
tariik_akan
Good luck, may Allah not cause any trouble, use Mehmet Bey bye ...
08.05.2020 18:08 # 8
ersin025
Welcome to our vehicle, I wish you auspicious auspicious throttle butterfly cleaning and adaptation. It cost me 50 TL.
08.05.2020 18:08 # 9
MehmetMehmet
[QUOTE = tariik_akan] good luck, may Allah not cause trouble by accident Mehmet bey use bye ... [/ QUOTE]
thank you so much...
08.05.2020 18:08 # 10
pesimistyle21
SISTER FIRST, NO GOOD LUCK, God do not cause accident
It is normal to buy a car that is so problematic for this money, or if you don't give it to you, we will not give this vehicle 16 either. If you bought a car without any problems, brother ...
08.05.2020 18:08 # 11
sanane79
slm. friends I need help in me last month 2007 model 307 bought 1.4 comfort package, car 150 thousand also have some problems in me, I did not work the oxygen sensor, I changed the fuel was incredible, I did not try the fault, the heat was burned, the car burned down after the day, it was normal, I said it was okay said. let's say there is a tremor in the vehicle, and I got the misfire computer, the second engine said there was a malfunction, went to the mechanic, he said either the valves are the bobbin or the spark plugs, the bob was 200 tl mercury spark plug, I did not change the 60 tl, but I am afraid it will be a problem in the valves, all the trouble will be in the valves, the problem will be in the valves There was a very light oil on the spark plug ends, the car tube was 2 years old with a tube tup fit warranty and 30 thousand ticked tuple estimates, I am waiting for your help and experience.
08.05.2020 18:08 # 12
MehmetMehmet
[QUOTE = pesimistyle21] SISTER FIRST GOOD LUCK TO GOOD May God not crash
thank you God did not give any trouble to anyone but when I was buying, my teacher and my friend told me whatever it was (he said it was a matter of late work), we also went to the authorized service together with the expertise report and the car came out clean, so I think it is a matter of late work for a 10 year old vehicle. It is quite normal to have problems. In the 2004 model vehicle you bought, my age and tomorrow may cause problems (hopefully it does not), not only zero vehicles, but even zero vehicles can cause problems. After all, I just asked the reason and solution of this problem ...
08.05.2020 18:08 # 13
barishrocker
If the screen and tape on the chest are problematic, a multimedia product can be considered by replacing both.
http://m.gittigidiyor.com/urun/aciklamasi/97658151
08.05.2020 18:08 # 14
MehmetMehmet
[QUOTE = barishrocker] If the screen and tape on the chest are problematic, a multimedia product can be considered by replacing both.
http://m.gittigidiyor.com/urun/aciklamasi/97658151[/quot A]
thanks...
08.05.2020 18:08 # 15
barishrocker
You're welcome. I saw someone's practice; I have attached ipad to the vehicle. All vehicle information; He transferred speed, breakdown, fuel, etc. to the console and fixed it to the console.
08.05.2020 18:08 # 16
ersin025
In fact, we need to take it off from the 206 screens that serkan also mentioned, but I still haven't changed it.
08.05.2020 18:08 # 17
MehmetMehmet
[QUOTE = MehmetMehmet] friends, this is the 4th question, that is, when the car is idle, there is tremor in my legs, even if it is very mild, this is the calibration because the throat butterfly is cleaned, as the friend said, if I say balance or something was done.
friends, is there anyone to help?
08.05.2020 18:08 # 18
MehmetMehmet
actual
08.05.2020 18:08 # 19
bluefire
I tried the led T5 bulb for the display in my 307 car. The results are very satisfying. It became visible during the day. But a little better I used a led. It shines quite a bit.
08.05.2020 18:08 # 20
ErDeM___
[QUOTE = MehmetMehmet] [QUOTE = MehmetMehmet] this is the 4th question, that is, when the car is running idle, there is a tremor in my legs even if it is very mild, this is a calibration because the throat butterfly was cleaned as your friend said?
guys, is there anyone to help? [/ QUOTE]
Hello, I just joined you. I used the 2004 model 307 tecnoplas for a long time, it was necessary to adjust after idle throat cleansing, but if it still vibrates, it may be related to your spark plugs.
Page : / 2
