I bought 17 wheels, how much money will the cargo hold?
08.05.2020 15:12 # 1
Uploaded with ImageShack.us
friends, we bought the wheels but with 17 inch tires, how much will the shipping cost be from ORDU to ANKARAYA, if anyone has any information please help.
08.05.2020 15:12 # 2
dukenukem82
57 tl is about the same in other cargo, it is approximately the same in other companies.
08.05.2020 15:12 # 3
Thank you brother for your information ...
But the distance from the army to Ankara should not be too far
08.05.2020 15:12 # 4
Muhammet CAKIR
only wheels were 28 tly from old to kutahya, although it was agreed that my wheels were 15 "
08.05.2020 15:12 # 5
I hope that something cheap will cost me nothing.
Bid 206 or 205 45 17 rim would make trouble.
08.05.2020 15:12 # 6
dukenukem82
makes some trouble without playing around in the car in full laps and bumps
08.05.2020 15:12 # 7
when I turn the steering wheel fully, it rubs my hood or other beria.
08.05.2020 15:12 # 8
hakan308
In the full round, the hood is a flange and its solution is to install a flange.
08.05.2020 15:12 # 9
Yusuf Tekoglu
205 No, my brother, I did not wear it.
08.05.2020 15:12 # 10
pusat81
I had 205 40 17 on me.
08.05.2020 15:12 # 11
They used to put it on the intercity passenger bus. You'd throw a pack of cigarettes and take care of the crew Göz Kırpma
08.05.2020 15:12 # 12
Yurtiçi Kargo costs 100 TL.
08.05.2020 15:12 # 13
What does this flange do? I don't understand what happens when I put it on.
08.05.2020 15:12 # 14
[QUOTE = pusat81] I had 205 40 17 on me you can't make a full lap [/ QUOTE]
I also have a 3.5 cm eibach bow in the bidet.
08.05.2020 15:12 # 15
hakan308
the tire comes out but if you attach a flange with 3.5 eibach you can rub the hood at this time
08.05.2020 15:12 # 16
Emre Ekrem
I use 306 or 205-40-17, probably 206 can also cause 45 cheeks.
08.05.2020 15:12 # 17
When I use 205 40 17 tires with 206 RC and those wide fenders, I think that you will get 45 17 ... it is not true ... because the vehicle will fall ... you will fall. your fuel will increase. you will have kite problems ...
essentially the most beautiful tire to 206 is 195 45 16 ... of course I would like to remind you of the importance of offset in this rim event. Some rims will surge inside the rear fender as soon as you have fitted it, and some to the fender mouth. At this point, offset plays an important role ...
the cecol 2011-03-29 09:46:53
08.05.2020 15:12 # 18
dukenukem82
If you take the rim at offset values between et16 and et25, the probability of rubbing is minimized.
08.05.2020 15:12 # 19
[QUOTE = dukenukem82] If you get rims at offset values from et16 to et25, the probability of rubbing is minimized. [/ QUOTE]
Although I am not sure, I think 206 should not fall below 20 offset. this time he goes out to the outside by rim. it can be applied to the mudguard. Because the 206's hub sizes are usually like 307s. For example, the offset of the 16 "multi-spoke wheel that comes at the top of the 206 gti and cc is 28, of course, let's remember the importance of the rim width at this time :)) basically, this rim is not a heat.
the rim cap is separate
rubber cap separately
The width of the rim is separate
offset separately
etc etc a lot of it is necessary to pay attention to different sizes
I do not recommend using flans. There are friends who use it. But it is necessary to use long bjones, etc. troubles can occur. sometimes it can not balance. They want good money even if it is already flan. I think it is pointless ... I will put the money I will give to the top of the wheel of the rim, I will get a better rim as well :)
but for example the size of 306 is different. The original rims of the 306 gti are offset 18. Mine is tickling inside because it is 24.
08.05.2020 15:12 # 20
I put the picture of the rims on the top page of the announcement, I bought a brand of toora brand wheels.
Page : / 2
