I ate the head !!!!
08.05.2020 18:26 # 1
alicanakca
THE FRIENDS ARE A FINE WAY BETWEEN 50 TO 60 ONLY IN MY CAR.
08.05.2020 18:26 # 2
Barut
Have you checked the tires, what are the balances?
08.05.2020 18:26 # 3
alicanakca
a alicanakc to 2014-04-08 22:38:36
08.05.2020 18:26 # 4
alicanakca
[QUOTE = Red dream] Have you checked the tires, what are the balances? [/ QUOTE]
I checked all the tires no problem
08.05.2020 18:26 # 5
Barut
Last year, when I got a new wheel tire, the roar was starting when it reached 50 km, the rot was improved after the balance adjustment.
08.05.2020 18:26 # 6
alicanakca
[QUOTE = Red dream] Last year, when I got the new rim tire, it started when it went up to 50 km, the rounds improved after the balance adjustment, and if the tires are too large or not compatible with the vehicle, it makes hum after 50 km. [/ QUOTE]
but after 60, can we cut it anyway?
08.05.2020 18:26 # 7
Barut
[QUOTE = alicanakca] [QUOTE = Red dream] When the new rim was added to 50 km last year when I got the tire, the rounds started, after the rot balance adjustment, if the tires are too wide or if the dimensions are incompatible with the vehicle, it makes hum again after 50 km. [/ QUOTE]
[/ QUOTE] Vallahi, whatever I say is a lie, I say you look at the balance balance setting.
08.05.2020 18:26 # 8
iso307
There may also be a bearing that has deteriorated.When the car is on the lift, have the wheel blanks checked.
