I appreciate the lpg, what is the fuel value.
08.05.2020 15:14 # 1
2 days ago, I appreciated the lovato branded lpg ...
At first, I filled 20 pounds of gas, and after it was over, I filled my car's tank from 1.904 ...
I went 103 kilometers, but still none of the lights went out.
then i went to say i fulle i took 17 million gas for man i think i am waiting for a comment from friends who know it because i do not understand if i do not understand
facemelow to 2011-04-07 15:20:20
08.05.2020 15:14 # 2
Look, this heat system is roughly so. If you consume few liters with gas, you will consume 10-15% more in lpg.
According to what you said, you made 17TL / 1.904TL = 8.93LT lpg, as well as 103 km of fuel consumption. In general, it is very good :) Of course, depending on the place of use, it is very different.
08.05.2020 15:14 # 3
So a good value, this cecoli master.
08.05.2020 15:14 # 4
what more can you say ... as far as you said roughly you did 100km to 9lt :))) besides 17kr :))
I made 100 km with 9.45 LT lpg in the last tank. generally, it is the result of the use of an amount of out-of-town ...
the cecol 2011-04-09 22:53:16
08.05.2020 15:14 # 5
No other value would be expected from a car driver like me anyway, I would never accelerate, come to the gas, go slow, etc. etc etc.
thanks cecoli master.
08.05.2020 15:14 # 6
[QUOTE = facemelowe] No other value would be expected from a car driver like me anyway, no sudden speeding up, going to the gas, going slow etc. etc etc
You're welcome. continue just like that :))
Write your signature lovato lpg. is this scarce lovato easy fast you got it ???
08.05.2020 15:14 # 7
yes lovato fast but i don't know if it is easy ..
The man who wore it said the latest version.
08.05.2020 15:14 # 8
probably the last version of easy fast
08.05.2020 15:14 # 9
I don't know, I'll check it out tomorrow.
08.05.2020 15:14 # 10
If he writes, he writes on the stp above the lpg. It doesn't write anywhere else ... it's not very important
08.05.2020 15:14 # 11
Well cecoli master sagolas.
08.05.2020 15:14 # 12
wow, I learned to compute it too.
08.05.2020 15:14 # 13
then let's say, okay: DDD
08.05.2020 15:14 # 14
maşallah master, maşallah :)
Can't we burn this less ..
The guy connected something to the pc and he did something, but since I was away from these issues, I did not get out of it :)
08.05.2020 15:14 # 15
metin
good luck, mahal. your values are very good.
08.05.2020 15:14 # 16
[QUOTE = facemelowe] maşallah master my maşallah :)
Okay, don't go further. I will burn less, you will burn the breakdown light :)) You will give the fuel that a motor needs. If you cut it down or increase it, you can't get anything, on the contrary, it may start to be harmful.
08.05.2020 15:14 # 17
Serhun
Thanks for sharing. I also think 206 LPG or LPG you could not decide. I do not want the volume of the trunk to narrow, but :-(
08.05.2020 15:14 # 18
If you want baggage, you will get the most beautiful diesel ...
08.05.2020 15:14 # 19
Serhun
We're going to break the heel a little bit, but I'm sorry that the new topicle won't get dirty.
Let's buy diesel, but I think there is no PUG diesel automatic 206. Corsa is there, but how could they look and I can't try to collect engines that is around here. 5-6 years old unknown kilometer diesel can headache. Generally, the tools I use frequently were diesel, but I took good care and sold them in a short time.
Also, isn't there a sheet metal casing instead of a spare wheel? There were those who made such a system for the 307s I remember, being 35 cm above the ground.
Let me tell you my usage condition, it will go 3-4 kilometers in a place with a flat geography and will come back from the same place. In other words, the vehicle will be stopped again without warming up (switching to LPG). Apart from this, when one goes on the long road, he will make 30 km or 100 km on the straight road. Do not you need LPG?
08.05.2020 15:14 # 20
My brother corsa is not fully automated as far as I know the diesel vending machines. It is an automated flat vat called easytronik. work with the familiar clutch set ...
There is no need to install tanks from the bottom of the 307. Because the steppan is already inside
Warehouse can be mounted from 206 to the bottom. provided that it is at normal height. One of our latest systems, we attached it to our brother's 2000 model 206 XT 1.6 8V vehicle ...
If the distance to be used is short, a system can be installed that can switch to LPG earlier.
I tried this on my own car. I shot it in the video :)
In 5C cold, I left marching without touching any gas like I pressed marsa.
I usually progress slowly after running and wearing my belt. When you move, it gets worse. 200-250 meters on coldest days. my car goes to lpg at 15C.
Page : / 2
