I am waiting for your urgent thoughts
08.05.2020 16:57 # 1
furkan111
1- friends, I changed my car's printing pad today ... compared to the past & nbsp; I wonder if they could have installed 1.4 of my car with a performance dust ... 1.6?
2. debraj grasping at the same place. But the car gets up easily from the old one but it is not very fluent. / div>
08.05.2020 16:57 # 2
kirmizi306
The LPG setting goes away when the battery is removed. Probably the problem is caused by the problem.
08.05.2020 16:57 # 3
furkan111
I understood thank you....
08.05.2020 16:57 # 4
comondx
[QUOTE = red306] When the battery is removed, the LPG setting will go away. Possibly the problem is caused by the problem. I would like to make an LPG setting again. I think it shouldn't be. because it is ridiculous. do you have any exact information? otherwise, many people would be walking around without notice.
08.05.2020 16:57 # 5
furkan111
yes, ask for certain information, but it is true that the performance is not the same as before ... there is a possibility that it has changed
08.05.2020 16:57 # 6
kirmizi306
Well, I changed the battery, in the winter, I was in the car.After that, the car was very jerky at idle, and it was not accelerating after shifting after shifting. br>
My vehicle is 306 and 98 models. LPG is ordered.
08.05.2020 16:57 # 7
furkan111
Exactly, I have that problem, or 1.6 xs 206 should take off at takeoff.
08.05.2020 16:57 # 8
kirmizi306
My teacher, you can consult where you did it anyway. If you don't get it right now, do not waste your money, but it was my face.
By the way, this problem does with spark plug cables and spark plugs. It is possible that they have.
red306 2012-08- 02 22:34:28
08.05.2020 16:57 # 9
furkan111
I also changed the spark plugs ... I said let's change the cables too, they said there is no cable in these 2000 1.6 206 xs
08.05.2020 16:57 # 10
When replacing the battery, the negative battery is usually connected to the negative terminal with the spare battery, so the vehicle is not left without electricity.
08.05.2020 16:57 # 11
kirmizi306
Sir, if the vehicle is doing the same problem on the gasoline, it is not LPG. It is the easiest way to understand it. If it is doing only LPG, then it is the tuner.
Maybe one of the spark plugs you have installed may be defective.
08.05.2020 16:57 # 12
furkan111
Do you have a car?
