I am waiting for the help of 307 users .....
08.05.2020 14:55 # 1
Faruk
Hello friends, I have been using my 2007 model vehicle for about 8 months, it didn't feel like it at first but nowadays it goes down to the bottom when I try to lift the driver's side and side passenger glass. thank goodness after closing my windows. Maybe most 307 users are living this but
I heard that there was a chronic mistake, even if we renewed the glass control part, it was said by you that it will be the same again in the future.
Since the weather is cold, I open the glass a little bit, but when I say something I lift or remove it completely, it comes down completely. This time, because I do the same thing every time, you can share what kind of solution is applied by those who encounter the same situation and help me solve my problem ....
thanks in advance.
08.05.2020 14:55 # 2
bulent 77
When you lower or lift the glass, it will stop pressing again
08.05.2020 14:55 # 3
Faruk
[QUOTE = bulent 77]
Stopping is okay, there is no problem in it, but my goal is how we can solve this problem, what can be done to get up without any problems at once.
08.05.2020 14:55 # 4
mabolla
Did you try pulling the button up and counting up to 10 after closing the window?
08.05.2020 14:55 # 5
THE SAME WAS HAPPENED FROM MY FRIEND, A BEAUTIFUL ELECTRICAL MASTER FOUND 20 LIRAS GIVEN LIKE CILLOP INSIDE ALLAH GETS A GOOD MASTER
08.05.2020 14:55 # 6
dogu
I have the same problem in 2006 307. The glass motor that I took to the service said it should be defective, they asked for 350 liras about 2 years ago. I have been using it for 2 years. Star
08.05.2020 14:55 # 7
Faruk
[QUOTE = mabolla] Did you try to pull the button up after counting up to 10 and try again [/ QUOTE]
trouble on buttons ...
How can we process the buttons, whatever change or clean ...
08.05.2020 14:55 # 8
okan77
I think there was a subject about cleaning ... If you review the site again ... It was removed and cleaned ...
08.05.2020 14:55 # 9
Faruk
[QUOTE = okan77] I think there was a topic about cleaning ... If you review the site again ... It was removed and cleaned ... [/ QUOTE]
I had read it before, but it was not in my mind, there was a subject called 307 window control disassembly, when it was found that the subject was quoted in one place, but the subject was deleted.
08.05.2020 14:55 # 10
yzt06
friends, I think of something else. I think it has nothing to do with buttons.
In the 307s, there is a system that prevents jamming on the windows ... If there is resistance against the glass closing, that is, if our hand is trapped, it automatically opens the window.
08.05.2020 14:55 # 11
bayelektronik
Hodja, I tell you that you need to clean 100% 100 buttons. It is a very simple problem. To fix it even more than 20 lira. Open the screw already resembles kuman.
08.05.2020 14:55 # 12
Faruk
[QUOTE = bayelektronik] my teacher, I have to say that you need to clean 100% buttons. It is a very simple problem. To fix it even more than 20 liras. Open the screw already resembles kuman.
experience disassembling and cleaning. the problem is solved ...
08.05.2020 14:55 # 13
eneslan
Hello friends, since I am a new member, I am writing a new one about this subject. 4 months past, though. I have 2006 model 307, I have been experiencing this problem for about 1 year. The front two glasses are throwing down when closing the glass. The smart glass is engaged. The last right rear window had started to jam, and the servants got to the service, they cleaned the mills of the glass, and they cleaned. but at this time, the left ten windows started to be stuck and do not improve. They say water may have run off. As a solution, the board had to change, the price of 250 TL. I said keep it, I did not change it. What seems like a minor problem is more annoying in the hanger.
08.05.2020 14:55 # 14
muratgulen07
about two months ago, the same problem was brought to the service, took it to the service, cleaned it brought it, it did not take 2 minutes, it took 30 lira .. whatever I said it was okay.
08.05.2020 14:55 # 15
kabus
Well, chronic, I have the same problem on the windshields and a disgusting creaking sound. Embarrassed I go and get it clean after 2-3 days the same, sometimes just because I catch the car Embarrassed It's like glass teasing us Embarrassed when I try to close it opens or vice versa, but somehow the same thing doesn't happen on the rear windows ??? interesting so there is no abnormal working condition or squeaking sound on the rear windows nightmare 2010-10-20 10:37:00
08.05.2020 14:55 # 16
serdia
FRIENDS HAVE THE SAME PROBLEM, ONLY CLEAN WITH ALCOHOL BRUSH AND CLOSE IT WORKS.
08.05.2020 14:55 # 17
dogu
I was just doing the front passenger side and started to do it on the driver's side for the past 1 week. Embarrassed
08.05.2020 14:55 # 18
qw12
I thought of opening and cleaning. I was encouraged to hear from friends now. I will do it as soon as possible.
08.05.2020 14:55 # 19
qw12
Today, I removed the left side and cleaned it, guys. Just like we cleaned the television remote. There is silicon on the control circuit. Ancaaaaak
There was no difference, but the glass came back again, even though I did a lifting action. I just realized that. The glass also makes very light back and forth movement during the up and down movement. With your hand, you can move the part of the glass close to the middle column towards the hood or half a cm towards the trunk. Here, when you command the lift up, when you move on the other axis (slightly forward or backward) in the glass slot except the upward direction, the jam protection mechanism activates and lowers the glass down. You have to remove the door trim and find the reason for that movement and tighten or replace whatever loosens the piece. I think this is the definitive solution. Instead of dealing with it, I decided to ride like this.
08.05.2020 14:55 # 20
Faruk
[QUOTE = yzt06]
In the 307s, there is a system that prevents jamming on the windows ... If there is resistance against the glass closing, that is, if our hand is trapped, it automatically opens the window. [/ QUOTE]
It seems to me that there is a problem in this system, but I could not clean it by any means, even if I could not go to the service and ask for it, let's use it a bit more, maybe our friend who found a solution will inform us ...
Page : / 3
