I am waiting for an urgent comment
08.05.2020 17:19 # 1
turquaz
First of all hello, good evening;
Friends 3 weeks ago, I had a tube installed. now & nbsp; I said to the master that the water leak was leaking over time due to the engine's top cover gasket. My hand was convicted. I bought the car for 600 TL anyway, I'm going to work as usual, hopbaaa & nbsp; The gearshift lever remained in my hand, the rope rope tip was licked, the master came and the new one came. hey line the problem does not end the friend changed to 400 tl. however, it is now difficult for the vehicle to enter gear 1 and 2. I took it to the master, where the plastic part of the plastic rope & nbsp; He said that when you tighten your circumference because it was yawning, the gap would go away. We said ok again, today there is a problem with gear shifts again. Now I wonder what is the name of the plastic part? Is it possible to change the part that flashes in the place where the gear rope passes? Reviews
08.05.2020 17:19 # 2
elestern
tell me if you solve
08.05.2020 17:19 # 3
turquaz
[QUOTE = elestern] Tell me if you solve it [/ QUOTE]
there is only one thing I can learn now, my friends on the jersey help, but there is a place where this gear rope is attached to it & nbsp; this is what a plastic piece flexes & nbsp; they say, but I don't know what this piece is like or anything!
turquaz 2013-01-27 23:14:22
08.05.2020 17:19 # 4
caner_1985
my friend, I also parked in a grande point car, I run it, I stayed in the third gear, the gear stick remained in my hand, I changed the rope.
08.05.2020 17:19 # 5
elestern
When I pass from 1 to 2 or kills from 3 to 2, I don't officially switch from 1 to no bidet.
08.05.2020 17:19 # 6
emin15
If you think your vehicle is 307 1.6 gasoline, the plastic part may be a half sleeve shaped part at the end of the gear rope, with the room gear rope.
08.05.2020 17:19 # 7
loiz
In the 206s, I know that the shift from gear to gear is going. By the way, don't expect the vehicle to move to 1 without stopping, my gear shifts are hard, especially in 1 2 others, rhat, I was thinking of changing plastic wear parts to ease the gear.
08.05.2020 17:19 # 8
turquaz
[QUOTE = emin15] If you think your vehicle is 307 1.6 gasoline, the plastic part may be a half sleeve shaped piece at the end of the gear rope, together with the room gear rope. I wonder if there is
08.05.2020 17:19 # 9
emin15
Is it easy to switch to 1 and 2 when it stops the car?
08.05.2020 17:19 # 10
elestern
date
Reviews
08.05.2020 17:19 # 11
elestern
Could you inform us a bit about my teacher, like & nbsp; i.e. straight reverse,
elestern 2013-02-07 20:28:21
