I am undecided if I bought 1,4 307 me 16 rc or 17 rc |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Wheel Tire Selection | |
| 08.05.2020 19:54 | # 1 |
| 08.05.2020 19:54 | # 2 |
OguzhanKucuk61 |
If you look at going rather than visual? Anyway, 1.4 vehicles will tire even 16, never think of 17. If you are going to wear 16.
| 08.05.2020 19:54 | # 3 |
I recommend 17 "as long as you get the original. It will not tire too much. If you buy 16", the replica will be almost the same as the weight of 17 ". My vehicle is 1.4 68 horsepower 16 "plugged 5-10% reduction in traction. Your vehicle does not tire 90 horsepower. If you look at the member vehicles in terms of visuals, it should be in the forum 307 RC rim mounted :)
| 08.05.2020 19:54 | # 4 |
OguzhanKucuk61 |
Are your rims original? Original size 185/65/14 How many parts of the 75 horsepower can I wear?
| 08.05.2020 19:54 | # 5 |
Okay, it feels like it would be nice to find that otjilqnüde in the correct version of it and put it down and put it down with 3.5 bows.
| 08.05.2020 19:54 | # 6 |
OguzhanKucuk61 |
No 16-inch original? It gets cheaper both?
| 08.05.2020 19:54 | # 7 |
OguzhanKucuk61 |
You will wear 3.5 mm in 17 followers. The car will be hard. If it is original, it goes better than 16.
| 08.05.2020 19:54 | # 8 |
[QUOTE = OguzhanKucuk61] Isn't there 16 inch original? It gets cheaper both? [/ QUOTE] 16 originals missing.
| 08.05.2020 19:54 | # 9 |
If I wear 16 how many tires should he size 205/50/16?
| 08.05.2020 19:54 | # 10 |
OguzhanKucuk61 |
What is the original size?
| 08.05.2020 19:54 | # 11 |
[QUOTE = OguzhanKucuk61] What is the original size? [/ QUOTE] 195/65/15
| 08.05.2020 19:54 | # 12 |
OguzhanKucuk61 |
205/55/16 or 225/50/16 are perfectly suited
| 08.05.2020 19:54 | # 13 |
OguzhanKucuk61 |
If you do 205/50/16, the total diameter will drop by 3.5% and this is not recommended.
| 08.05.2020 19:54 | # 14 |
OguzhanKucuk61 |
And 205/55/16 is such a size that good tires come at a very affordable price because it is popular and easy to find. This is the logical size I would suggest
| 08.05.2020 19:54 | # 15 |
[QUOTE = OguzhanKucuk61] Are your rims original? Original size 185/65/14 How many parts of the 75 horsepower can I wear? [/ QUOTE] No, it's not original. There is no RC model at 16 ". Unfortunately there is only 17". I suggest you wear the original 15 "if you want to wear it. CC wheels with wind rose are also an ideal model for this job :)
| 08.05.2020 19:54 | # 16 |
OguzhanKucuk61 |
Just like you said, it happens exactly on 195/55/15 :)
