I am thinking of having my chip applied to my vehicle |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 16:31 | # 1 |
GiTaRRa |
| 08.05.2020 16:31 | # 2 |
If your vehicle is in stock, you will not see much benefit from just making chips. I recommend making at least filter + straight pipe and end silencer before chip.
| 08.05.2020 16:31 | # 3 |
GiTaRRa |
If you bind 51 straight pipes, I guess I will not have to make it certain.
| 08.05.2020 16:31 | # 4 |
GiTaRRa |
what is scok? I don't know what happened 1999 xr stock I wonder
| 08.05.2020 16:31 | # 5 |
Stock .. that is, the vehicle with the original parts without engine modification
| 08.05.2020 16:31 | # 6 |
GiTaRRa |
hee mate i bought the car from the lady who never played the car napacaz now can you share it step by step & nbsp; straight pipe ok .. < / div>
| 08.05.2020 16:31 | # 7 |
A straight pipe + quality end silencer (Remus, sebring, HKS or Supersprint), open air filter and software tool will slightly rejuvenate. If you want to run seriously, you have to replace the intake system, the camshaft and the pulleys and grind the cover with a good timing. you fight :) |
| 08.05.2020 16:31 | # 8 |
GiTaRRa |
my friend thank you or good at least get better help from an experienced person ..
| 08.05.2020 16:31 | # 9 |
[QUOTE = GiTaRRa] my friend thank you or good at least you are better thanks to get help from an experienced person .. [/ QUOTE] You are welcome in Istanbul and I will help if you want to install the tool. |
| 08.05.2020 16:31 | # 10 |
GiTaRRa |
ee I'm in konya
| 08.05.2020 16:31 | # 11 |
yigidow06 |
will these be in a diesel car, hodja
| 08.05.2020 16:31 | # 12 |
[QUOTE = yigidow06] these would be in the diesel vehicle teacher [/ QUOTE] diesel power easier chip application is better than gasoline. carries the car :) |
| 08.05.2020 16:31 | # 13 |
106 1.4 xr vehicle, you can not get any efficiency, no need to trick yourself & nbsp; you will spend money in vain, & nbsp;
| 08.05.2020 16:31 | # 14 |
yigidow06 |
[QUOTE = umutrizaergen] [QUOTE = yigidow06] would it be in the diesel vehicle hojam [/ QUOTE] easier to apply power in diesel chip application is much better than gasoline. / 60s makes a trbo car :) [/ QUOTE] what does it do, what is the cost of the master
| 08.05.2020 16:31 | # 15 |
[QUOTE = sahin-peugeot] 106 You can not get yield from 1,4 xr vehicle, don't worry, you don't have to fool yourself, you will waste money for nothing, |
| 08.05.2020 16:31 | # 16 |
I also have 106 quick I am in Istanbul I want advice |
| 08.05.2020 16:31 | # 17 |
Alicilik |
[QUOTE = yigidow06] & nbsp; what does it do, well the cost of the master [/ QUOTE] 1.4 This process can easily be used for 68 hp HDi engines maintained. Many companies are doing this together with software companies abroad. Very good craftsmen do this work with their own hands. There are many masters who have made a name about it in Ankara. You can get a result with a little research. The cost of this process varies between 250tl and 1500tl depending on the process and the process. There are 1-2 level events, you can learn more from the people who do these things, but for a long-term use, it is necessary to keep the level 1, and the high performance that will be taken from diesel cars will decrease the life of the vehicle. There are some chipboxes that are bridged to the electrical parts of the engine, doing some of this process and giving you a noticeable performance difference. These can cost more than normal chiptuning. As mentioned in previous articles, this process is more efficient in vehicles with turbo engines using diesel fuel. If it is done carelessly and excessively, it can damage your engine many times more. That's why we need to be very careful. A level 1 chip operation can increase the power of a 68 horsepower to 90 horsepower. You play with 1.4 gasoline already very comfortably, but with chip 1.6 (vti a bit difficult but belllkiiii) you can also play very comfortably. Reviews |
