I am facing an interesting mistake
08.05.2020 21:16 # 1
lilokan
Friends give antipullotion fault error when I drive 130 u by car. When the Bikac watch does not get in the car, I look at the lamp. I am trying again after 130 u hop hop again the same mistake. I wonder what the problem is
08.05.2020 21:16 # 2
Ouzhan0734
This is the mistake of my head too ... There is no ignition unit left in the car ... I have already built a new engine. Hopefully you will find a solution because I started hating the car.
08.05.2020 21:16 # 3
lilokan
[QUOTE = Ouzhan0734] This is my troublesome mistake too ... There is no ignition unit left in the car ... I have already built a new engine. Hopefully you will find a solution because I started hating the car. [/ QUOTE]
My teacher is not burning all the time. yesterday came to me. It only gives a warning when 130 is over. I'm really sick
08.05.2020 21:16 # 4
Ouzhan0734
The error you received is polluting the environment error. There can be many reasons for this. Error codes must be read from the vehicle and diagnosed accordingly. In the meantime, it is better to look at the error codes with the PP2000 device.
08.05.2020 21:16 # 5
whisky
the oxygen sensor may be all of the fuel you get. If the vehicle does not have any negative effects, do not worry about it. it usually does it from fuel. If the vehicle has LPG, the warning lamp lights up like most vehicles do. If it is uncomfortable, look at the car, if there is no problem and it still sticks to the head when the light is on, buy 1 from 20-30 TL and delete the error code from the phone. I was doing so.
08.05.2020 21:16 # 6
lilokan
[QUOTE = whiskey] oxygen sensor, you can get fuel or something. If the vehicle does not have any negative effects, do not worry about it. it usually does it from fuel. If the vehicle has LPG, the warning lamp lights up like most vehicles do. If it is uncomfortable, look at the car, if there is no problem and it still sticks to the head when the light is on, buy 1 from 20-30 TL and delete the error code from the phone. I was doing so.
My vehicle stops the moment I touch the clutch after giving the error. It is dangerous not to show Allah.
08.05.2020 21:16 # 7
lilokan
[QUOTE = Ouzhan0734] The error you received is polluting the environment error. There can be many reasons for this. Error codes must be read from the vehicle and diagnosed accordingly. In the meantime, it is better to look at the error codes with the PP2000 device. [/ QUOTE]
Meanwhile, the representative connected the computer and went to the dust. When he accelerated, he made the mistake again. I got the error code right away. I wonder if the error code could be P1632 oxygen sensor
08.05.2020 21:16 # 8
lilokan
or if the battery was off the pole and it waited in the morning, I think the brain would be reset. Would it be useful
08.05.2020 21:16 # 9
whisky
Even if you do not press the gas, the vehicle will continue to operate without using fuel under the effect of rolling tires. However, if the clutch stops, it seems to me that there is no fuel. I was wondering if it does not ignite at high speed or if the fuel pressure is insufficient.
08.05.2020 21:16 # 10
lilokan
Even if you do not press the [QUOTE = whiskey] gas, the vehicle will continue to operate without using fuel under the effect of rolling tires. However, if the clutch stops, it seems to me that there is no fuel. I was wondering if it does not ignite at high speed or if the fuel pressure is insufficient.
My teacher looked at it with a program called Delphi. P1632 POWER TRANSFER CONTROL MODULE gives an error called MONITOR FAILURE. The masters did not fully understand
By the way, I can start printing, does it have anything to do with it
Liloan 2019-07-05 08:32:18
08.05.2020 21:16 # 11
whisky
I don't think it will be because of the press pad. my teacher may be from ecu or electrical.
08.05.2020 21:16 # 12
lilokan
[QUOTE = whiskey] I don't think it will be because of the press pad. my teacher may be from ecu or electrical.
I ordered the printing pad yesterday thinking it might be possible. The room will change tomorrow. How will we solve this fault, teacher
08.05.2020 21:16 # 13
whisky
You can notice this in case your printing pad is finished, whether it's on departure or on the way of the vehicle, in gear shifts or in hand control by hand brake. If the vehicle is LPG, I would have looked at the LPG installation. If the diesel stops when you load it on the gas, maybe I would have an electric pump or an electrical problem. Mine is guess only. there are more knowledgeable friends I hope they can help.
08.05.2020 21:16 # 14
lilokan
[QUOTE = whiskey] My teacher may notice this if the pressure pad is finished, whether it is on departure or on the way of the vehicle, in gear changes or in hand control. If the vehicle is LPG, I would have looked at the LPG installation. If the diesel stops when you load it on the gas, maybe I would have an electric pump or an electrical problem. Mine is guess only. there are more knowledgeable friends I hope they can help.
My teacher gets up and the car trembles a lot and it slams from above. Stop tearing the handbrake no tears, but I showed it to many places. The pad will change tomorrow. As for the problem, I tried with gasoline, unfortunately, and the same error. Now I don't think they understand that every place I take for this mistake will be more distorted. If we only know the place to look
08.05.2020 21:16 # 15
lilokan
friends, thank you for your interest. We fixed the problem. As we guessed, the problem disappeared when the pressure changed. It will help if you encounter the same error.
08.05.2020 21:16 # 16
whisky
Get well soon. at least every part of the car was done without tampering.
