hydrolic wheel
08.05.2020 15:28 # 1
sezar206
slm friends pug 206 I have the car hard steering does not have full hydraulic feature, that is, it forces you to turn it with one hand. I used palio, the steering was like cotton. Since I bought this vehicle, when I put the hard steering wheel in reverse gear, it passes sometimes, sometimes it gets stuck. It is annoying, especially the steering is annoying.
08.05.2020 15:28 # 2
ose
If you compare it to another vehicle, my hard soft steering is not as good as you think, it does not give confidence in high speeds, you still check the hydraulic oil.
08.05.2020 15:28 # 3
Kemanyak
Have you checked the steering fluid? The hydraulics of the peugeot are a bit harsh anyway :-)) When putting on reverse gear and 1st gear, it is sometimes difficult to put on, this is almost every 206. If it is too extreme, the transmission will look at the gear lever connections, maybe wear is too much. Or your clutch may be out of adjustment. But as I said, the situation is the same in almost every peugeot. I suggest you get used to it.
08.05.2020 15:28 # 4
Kemanyak
As a result of my experience, I have reached that if you treat the gears of the Lions softly, you get immediate results. If you hurry a little, if you act hard, it stubs the gear lever :-)))) As the steering wheel Kankam says, it is often an advantage to be stiff.
08.05.2020 15:28 # 5
ose
By the way, it is also for the other vehicles that will use reverse gear first, put it back to the end, or reverse the gear or find the most suitable gear for 2-3-4-5- whichever is better.
08.05.2020 15:28 # 6
sezar206
I understood thank you. Thank God I had no trouble in 1st gear or in others. If the steering wheel becomes softer, it is enough for me to have a problem in my car or you normally said it was hard but it softens a little more in hot weather near the normal steering. There is no problem in the oil in the pump. I suspect the bellows, I will change it and see if it is big.
08.05.2020 15:28 # 7
se®k@n
The things that happened in all of your 206's are already .. Gülme
08.05.2020 15:28 # 8
berk2309
Ole is sometimes too soft on me.
08.05.2020 15:28 # 9
rifatseker
Well, in my 2010 model vehicle :) Sometimes it feels like it is soft, sometimes it is really hard :) :)))
08.05.2020 15:28 # 10
The topic of gear and steering is the same in my vehicle. this is because the gear teeth inside the transmission do not coincide. In fact, it can be in all vehicles, but it is seen in a large amount in our pugs. This is the norm like ...
08.05.2020 15:28 # 11
Already old renons are in the 1st place, our cars are in the 2nd place!
08.05.2020 15:28 # 12
ose
Friends are sometimes hard, sometimes soft, but road asphalt gravel speed is also taken into account, all of them affect. otherwise the hydraulic is the same hydraulic.
08.05.2020 15:28 # 13
emrnl
my 206 is actually not very good in maneuver, but good when going fast.
08.05.2020 15:28 # 14
sezar206
Come on we have to get used to the steering wheel .. it's okay on the long road or from the moment the car moves, but it turns with one hand while parking but it turns me :)
