hydrolic wheel
08.05.2020 14:57 # 1
scorpions_64
friends, there is oil leakage from the 206 gti hydraulic box, when turning the steering wheel to the left and right, there is a great oil leak, as a result of my research, the leaks from their seals are generally. repair team or something, said the masters. Where and how do I find this repair kit?
08.05.2020 14:57 # 2
peugeotefe
The seals of the steering box have exploded and do not give any results in the revision.
08.05.2020 14:57 # 3
ali oncu
Thumbs Up efe confiscated
08.05.2020 14:57 # 4
scorpions_64
first of all thank you for your interest. I live in the butler province, how do we do it? We will change the complex steering box? Where are their prices?
08.05.2020 14:57 # 5
metin
While there is a constant hum in my vehicle. Even when I break the steering wheel, the sound increases, I think it sounds hard, I think it comes from the steering pump. Is this normal?
08.05.2020 14:57 # 6
IF YOU CHANGE THE STEERING BOX IS THE PROBLEM. SERVICE ORIGINAL PARTS PRICE 1300 TL INCLUDING WORK
IF YOU GET EXIT, BETWEEN 250-400 POSSIBILITIES TAKE ZERO DOSTUM ORNESS SEARCH
08.05.2020 14:57 # 7
ALX
[QUOTE = quiet_20] there is also a constant hum in my vehicle. even when I break the steering wheel, the sound is increasing, it makes me sound hard, I think it comes from the steering pump, is that normal?
There is also a lot of noise from my steering pump. They call it electric, normal. Did you open the ignition, salutes Gülme ... In the morning, when the engine is cold, the sound becomes more pronounced. Can the sound be reduced, or is the event normal? I use 97 model 106XS. There was no leak. And when the car is full the steering wheel turns hard, is there a solution?
