hydrolic wheel
08.05.2020 19:09 # 1
alikrcoglu
friends 2000 modelv1.4 I have 206 vehicles, my steering wheel is noticeably harder than other vehicles, it is a little difficult to say this is normalmi hydraulics in 206s ...
08.05.2020 19:09 # 2
samet206
The steering of the 206's is a bit harder than the new cars, it has a heavy steering wheel. It should not be compared with today's technology. Nothing to do other than that.
08.05.2020 19:09 # 3
talip206
The steering is a bit stiff. But if there is excessive hardness, have the hydraulics checked. Sometimes tire pressure can also affect
08.05.2020 19:09 # 4
sezar206
It is difficult to comment without using the hardness, but a steering wheel like cotton is not a problem if it is soft compared to a non-hydraulic vehicle. But there is not a very heavy one-handed freeze, if there is a problem in the pump or balls. I say goodbye with one hand, but I can say 3 times heavier than the steering wheel of my brother. You can even rotate it with your finger.
08.05.2020 19:09 # 5
tetik-soner
The steering wheel 206 is unfortunately hard ... hydraulic steering but I think it would be better if it is semi hydraulic.
08.05.2020 19:09 # 6
206cc57
Hi ,
My car was repaired as a result of timing breaks, the engine was repaired very well, but the steering is harder than before. I'm investigating, I'll have it done soon,
** I have oil in my steering pump, I don't know if the pump is working properly Shocked .
** Could there be a malfunction in the steering box? Ouch
** Made the shock absorber bearings old Shocked
** The belt connected to the steering pump has changed, does the belt not drive enough? Angry ..
08.05.2020 19:09 # 7
aliyurttakal
Hello, my friend, the same problem happened in my vehicle. The oil was leaking in the hose where the oil was gone. The oil was very hard because of the leaking oil. I made it.
