hydraulic steering pump malfunction.
08.05.2020 14:51 # 1
serFBdar
friends again I have a problem. (306 sedan 1998 model xn)
my hydraulic steering has gotten a little heavy, and they probably took the pump to the service. alone, the price of the pump is around 700 TL in service. What can you suggest for this price? I am waiting for friends who can give me help and information.
08.05.2020 14:51 # 2
haruncoskun
I had the same problem because their pump is powered by electric motor. Göz Kırpma
08.05.2020 14:51 # 3
the easiest way to find out. but it may not be from the pump. They're not sure what they're saying "probably". If you try to find it through trial and error, you will spend a lot of money. also this hardening happened in an instant?
08.05.2020 14:51 # 4
haruncoskun
I do not think there will be any other problem than the pump. In some models of pugs and renaults, the power steering takes power from the crank with the help of an electric motor rather than the crank, so the electric motor causes malfunctions over time. If there is no measuring device, it monitors the electrical installation by touching one end of the bulb to one end of the bulb (the car is running).
08.05.2020 14:51 # 5
[QUOTE = haruncoskun] I had the same problem as their pump is powered by electric motor. Göz Kırpma
you are wrong. In the 306s, the steering pump is not absolutely electric. It takes movement from the same belt together with the old air conditioner and alternator. Right fender on the hydraulic container.
08.05.2020 14:51 # 6
There is a hydraulic stick connected in parallel to the steering box of the 306s. There are valves that direct left or right direction to the hydro in the bass of the piston. there may be a problem in this section as well. It may be necessary to change the hydrology.
